I remember I did my old Monte Carlo, and it was only so-so.. The main problem converting is the condenser
coil will be undersized for 134a. So you end up running a high head pressure unless you slightly undercharge.
Which generally means the system will not cool quite as well as with the original R12 running at normal pressures.
Since then, I've always recharged R12 systems with R12. It just works better.
But I suppose that is easy for me to say, as I have plenty of it.. I still have a 30lb drum of it that is almost full.
It's easy to get a EPA ticket. It's open book per say, and a no brainer.. You can get them online most likely, and
if not, can send for the test material. Once you have that, you can buy it. They have a special automotive
ticket that covers the 1 lb cans. I've got every EPA ticket myself.. Universal, plus the auto can ticket, plus an extra
410a certification, which actually isn't required, but I got it just fer grins..
