I need help! My truck wont turn off with the key
lineman12345678
Post by lineman12345678 »
My truck is not turning off with the key. It has worked fine for years and now it's acting up. I replaced the ignition switch and the solenoid but it still has the same problem. Any Ideas?
Last edited by lineman12345678 on Thu Mar 06, 2014 5:35 pm, edited 1 time in total.
Mancar1
Re: I need help! My truck wont turn off with the key
Post by Mancar1 »
Most likely your ign switch.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
lineman12345678
I replaced the ignition switch first.
sargentrs
Post by sargentrs »
Try another solenoid. They are known for being bad right out of the box.
lineman12345678
Well it's working fine now. I am not sure what I did though. I was going through and testing voltages and checking connections and not finding any issues, I figured I would try it again and it turned on and off at least ten times with no issues. Maybe the new solenoid was stuck or something I did tap on it. I guess only time will tell.
sargentrs
Post by sargentrs »
Haha! Works every time. Just fiddle with it enough and it'll start working. Congrats. :thup:
Mancar1
Post by Mancar1 »
8) :thup:
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
