Yes, I had a giggle about the "Holley break in."
My Grand daughter and I took the Edsel for a drive yesterday and the same thing happened with the 600 Holley freezing up during the engine warm up. And it hardly ever fails that I just switch off the engine, wait a couple minutes then start it up again and "it's a happy time!"
A lot of folks get all upset, get in and floor the engine to clear it out which in most cases makes it worse, then get underneath the hood, remove the air cleaner and monkee futch with idle mixtures, choke settings, numerous trips to NAPA or Bumper to Bumper to buy carb kits or entire replacement carbs and ALL they had to do, is just switch off the engine for a couple minutes.
The first objective for this entire exercise is to be smarter than the carb, once that is understood the rest is easy. Ford has always battled carb ice as well have the other car engineers and all here have seen the air risers coming off the right hand exhaust manifold and Ford even went as far as installing plates under their Motorcraft carbs that allowed coolant that was warming up to flow through them to help melt the ice. Good idea until they sprung a leak.
This is a great post and a lot of information can be shared here. Take care and have a Great Easter!
