Moved it around the backyard, took the dented trim piece off the drivers fender. Realized I'm going to have to replace the tranny pan as the one that's on it has a big dent, and it leaves a red spot on the ground after sitting for a few days. Oh, well. A new pan always makes the tranny run better, right?
'69 Ford F250 C.S. Ranger 428 PI with gt 500 heads, racing c6, d60 3.73 limited slip, currently rat rod black (flat black) but going back factory Candy Apple Red / Wimbledon White
Took the ring gear off the differential, created dummy set up carrier bearings for the re-installation of my carrier, ordered my Detroit Locker for my Dana 60, cleaned and painted differential cover in prep of pinion installation, and performed a little shop clean up!
2017 Ford Raptor
1975 Ford Bronco
After meeting Rich (1972hiboy) and Mike (390bump) i was motivated to get my truck running after i pulled the cooling system apart in Jan. Got everything back up an running again after a few hours standing on my bumper to do the job, lifted rigs have many flaws haha only one small leak on the pass. side lower water pump. going to keep an eye on it an see if it goes away or ill pull the pump an reseal again.
When it was all running the brother an i went for a little cruise, i mean little seeing as i cant get out of 2nd yet haha thats for another day
-Mike- ECV 1849 Build>http://fordification.com/forum/viewtopi ... 22&t=68225
69' F250 Highboy 390ci.,NP435,Dana 24,HPD44,D60
67' Dodge Coronet R/T 440ci.4speed,D60, all numbers correct
72' Dodge Dart 440ci.727,D60,10ptcage street strip on meth 10.40s
05' Chevy Tahoe LT loaded for the wife an the baby duty
12' Ford Focus Titanium Hatch Back, Gas saver for the work week
Took the west coast mirrors off and installed sport mirrors.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Do not remember if I posted this, but I also added these goodies to the 390.
Keep on Trucking....John
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Painted the insides of the doors, installed the tinted glass once they were dry enough, poked holes in the rug and mounted the seat and belts, rummaged through the shed finding all sorts of missing stuff. Installed the modified lower front valance, ended up getting my turn signals working and currently working on offsetting the front bumper brackets to compensate for the 1.5" body lift.
Put in the new radiator and replaced two brake lines, while bleeding the brakes I here "POP, pshhhhhhh". (Broke a line) Going to order the rest of the lines monday.
(Also getting new Wheels tommorow)
'67 F-100, First truck, Bagged and bodied.
'70 F-350, Tow pig project
'97 F-150, Currently under Restoration
Actually, this was yesterday. I replaced the fuel pump and filter. No more fuel leak.
Now, I need to track down the fuel gauge problem. Gauge pegs when the sender is grounded, so the gauge is good. Replaced the sending unit, made no difference.
I guess it wasn't so much what I did (directly) to my truck today as what I did with it. I went to the wrecking yard and hauled home a pair of GT40P heads off a 97-1/2 up 5.0L Ford Explorer. I also grabbed the oil - to - water cooler and the harmonic balancer with the E D I S trigger wheel for a distributorless ignition setup.
