2005 F150 Battery issues.
Today I drove my 05 F150 to work and to some other places today. On my last stop before home I went to the store and it would not start when I was ready to leave. When I turned the key over it made an unusual click then all the needled on my gauges started to move erratically. I got a jump and it started right up and I drove home. Once home I let the truck run for 20 minutes. I turned it off removed the key then put the key back in, turned it over and the same thing all over. Any ideas?
- Mancar1
Re: 2005 F150 Battery issues.
How old is the battery? I had that issue on my 06 F-150. it was the battery.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Could be corroded terminals or charging system. Most autoparts stores will check the charging system battery for free.
