i plan to rebuild my t18 tranny, after that i think it should at least look sharp from the outside. right niw it's got a thick, semi-rigid layer of black gunk all over. i tried the "engine degreaser " from autozone , doesn't work. I'll try acetone but since i work inside the garage in my home, i tend to avoid such flamable vapor
thanks
how to clean gunk?
- knightfire83
Re: how to clean gunk?
Power washer, is what I used. Then after it dries, all sorts of wire brushes in a drill for the stubborn spots. Rinse & repeat.
1974 Ford F-100 4x4- 360 / manual.
1970 Ford F250 4x4 ~ Sold.
- thejunkman
Try kerosene. I don't think acetone will do much for you. After you get most of the gunk off, try something like http://www.spartanchemical.com/products/product/652000.We use it as a degreaser at my work, it's awesome stuff.
-Dave
1967 f100 long bed 2wd, 390, np435
1999 Mercury Grand Marquis
When you do your T18 make sure you replace your 2 nd gear synchro.
- DuckRyder
Simple Green
Power washer...
Power washer...
- Calfdemon
DuckRyder wrote:Simple Green
Power washer...
-Rich
Current toys -
Former toys -
Current toys -
Former toys -
Since I was going to rebuild mine, I just soaked it in teh parts washer of Simple Green. Worked like a champ.
or, money.
or, money.
On my tranny, I used Oven Off oven cleaner. It works great. Spray it on and then hose it off. Good Luck
oil eater from costco... Ive used most of the degreasers and whatnot, Oil Eater is by far the best in my experience. I havent used on tough built up grime like youre talking about, but that'd be my first move.
Apply generously at 1:1, let soak for 20 mins or so, pressure wash. you'll likely need to repeat if youre trans looks like I am imagining.
