My 1967 F100 in Az with A/C!!!
Re: My 1967 F100 in Az with A/C!!!
It's time to rebuild the carb. I ordered the premium rebuild kit for the Autolite 1100 or 1101 from Mike's Carbs and the hardware kit. Expensive kits.
I found an Edelbrock 1v intake for the same price I paid for the carb rebuild kits. I haven't driven across town to pick it up, and I don't know that I will. Heck of a deal, but just a hassle right now.
- flyboy2610
Sounds like you're moving right along on your project! That's going to be a nice truck!
- ximy
I put in a new V8 radiator last night because I was getting some leaking out of my old one. I have been experiencing the truck stalling when it has been driving for a bit. It stalls when I come to a stop at a light. The Phoenix temperatures can get the engine compartment warm when the outside temp is 110*. I imagine I need to put a larger heatsink on. I also will put a carb spacer on when we rebuild my Autolite 1100/1101 next week. I have seen articles on the web where they are made out of wood. I may give that a try.
I retarded the timing to 6* BTDC and that has helped with the hot-starts.
nice intake! if I were planning to keep the 1bbl i'd be searching for one myself. Nice progress.
1972 Ford F100 SWB Styleside 300ci I6 3OTT
1965 Mustang 289 T5 4 Weel Disc Brakes
1972 Chevy Blazer 4x4 350/350
1955 Chevy Big Window SWB Stepside
I got the intake today. The autolite carb gets rebuilt on Tues and I'll install the intake at the same time.
I am strongly considering doing some body work when it cools off and the shooting the whole truck, inside and out with lt blue and white U-POL Raptor tintable, UV Protected bedliner. I painted a VW bug a couple of years ago with the same stuff that I had tinted with OD Green.
My truck will never be a show truck. However, I think the Raptor liner paint would fit with the theme of purposeful upgrades to an already- bulletproof truck. 300 cu engine with a/c and a 3 spd. Slot mags and a 460 radiator. Function and utility oozes out of this truck. I love it!
Here are a few pics of my bug I had shot with it:
- jimmy828
looks like you are moving right along with your truck. Keep up the good work. Also like the little bug!
- jthulan
Great progress on the truck. Safety first!
1971 F100 Custom, 119,xxx miles
1984 Chevy Silverado, 437,xxx miles, original owner
1976 Ford Ranchero GT, 130,xxx miles
2015 Volvo XC60R, 60,xxx miles, daily
Well crude! I took the intake and carb off today to put the Edelbrock 1v intake on and observed my stock exhaust manifold was severely cracked in numerous places. That means I need a new exhaust manifold. I know that a popular upgrade is to put EFI exhaust manifolds on with dual exhaust with Offenhauser intake and a 4bbl Holley, but I don't know if I would see any felt performance with my Edelbrock 1v manifold and 1 bbl Autolite carb. Time to decide if the upgrade is worth the expense for a new exhaust, or do I just get another stock manifold? Hmmmm....
You will definitely feel an improvement with an updated aftermarket manifold.
I ordered a set of NOS Ford EFI manifolds. They should be here by Tues. I'll install them and have the truck towed to a muffler shop. I think I'm leaning towards a set of duals...
I installed the Duraspark II with an HEI module in a heat sink about 2 months ago. I was getting some stalling afterwards, which may have been due to a carb issue, or the HEI module getting too warm. My autolite 1100 carb was rebuilt yesterday, and will be installed on a new to me Edelbrock intake manifold. I also put EFI exhaust manifolds on at the same time, since my stock exhaust manifold was all cracked up.
While I was at it, I beefed up the heat sink. I used a 1/4" thick aluminum plate that was 4"x8", and mounted the first heat sink to it, and added the copper heat sink as well. In all, I have 3 heat sinks to tame the heat in our 112* weather. The 67 F100 with a 300 keeps getting better!
Heat sink Before:
Hear sink after:
New Y-pipe & Smithy Patriot 2.5" glasspack:
Edelbrock 1v intake and EFI exhaust manifolds (old exhaust is in the way- will be removed):
Heat sink Before:
Hear sink after:
