First start up video, 71 F100
dhenderlong
Post by dhenderlong »
After months of hard work, it's finally paying off. Starts right up. Ended up putting a start retard upon cranking. 25 degrees on start. Set at 34 degrees total advance, locked cam trigger. 6.5 psi of fuel to the carb.
Spins right up to redline.
Be sure to watch in HD.
Thanks to all that helped get me this far.
https://www.youtube.com/watch?v=YeyGdSE ... e=youtu.be
ximy
Re: First start up video, 71 F100
Post by ximy »
Watched the viddie!
Ye-hah!
What kind of motor?
Any cam break in required?
1967 f250 428
cowbay
Post by cowbay »
Hell Yea!!! Tell us a little more on the build :fr:
dhenderlong
.700 lift, ported AL cobra jet heads, forged bottom end. solid roller. makes decent power at 7500 rpm. ALL MOTOR. [and then some nitrous if needed :) ]
Frame up resto mod. bought when I was 18. 21 now. I've touched every bolt on this thing. Painted it in a junky barn, turned out like glass.
4.11 gears. c6 trans. 4500 stall, manual forward VB. street truck.
Camper Special
Post by Camper Special »
sounds Bad Ass.... I like the blue color :thup:
keep the updates coming
Out of order, I show you out of order. You don't know what out of order is, Mr. Trask. I'd show you, but I'm too old, I'm too tired, I'm too [censored]' blind. If I were the man I was five years ago, I'd take a FLAMETHROWER to this place! Out of order? Who the hell do you think you're talkin' to? I've been around, you know?..And Harry, Jimmy, Trent, wherever you are out there, [censored] YOU TOO! - Lt Col. Frank Slade
1972 F100 4x4 Calypso Coral
1970 F250 H/B Harbor Blue
1970 F250 CS Red
1970 F250 H/B Yucatan gold I'm back!
dhenderlong
Motor has dyno time on it for brake in. sorry for confusion. If i hurt the motor, its going to be off a large nitrous shot, not from starting. Though i was having backfire issues today. May take the start retard out. 7al msd box. Junk plugs could also be an issue...
ximy
Post by ximy »
dhenderlong wrote:.700 lift, ported AL cobra jet heads, forged bottom end. solid roller. makes decent power at 7500 rpm. ALL MOTOR. [and then some nitrous if needed :) ]
wow, that's a lot of stall.
1967 f250 428
dhenderlong
Was worried about overheating, but I picked up some temp gauges, a big a$$ radiator and trans cooler. Along with a sweet fan. Stock from a ford Taurus. Moves more air then most drag cars.
