Hi ya'll
Been a while since I have been on here. But I have been looking around a little at the builds you guys have going on, and was wondering in particular if anyone has info on doing a bumpside cab and bed swap on to the next gen chassis (80-96).
I have 2 decent candidates in mind to make it happen. but they aren't currently right in front of me to visually inspect them, and won't be for a while. So I thought I'd ask since I couldn't find, if anyone has an example of this swap. thanks for your help
don't know where else to ask about this
71 SWB / 2wd 302 Auto 3.70 posi
70 Boss 302 / close ratio 4speed 3.91 Posi
Re: don't know where else to ask about this
sorry, right details
2wd, half ton, long wheel base layout.
I know its not a 2wd but it had twin traction beam and those will interchange between the 2. and the truck chassis may be easier due to having rear cab mounts already and rear frame rails don't hump up as much but the front cab mounts bolted right in. You may just have to be the first.
and if any one notices i did go reshim my bed after looking at this pic
Also here is a slick sitting on an 80's bronco frame.
Phill
78 Mustang
67 F250ish
2010 F250 Harley Davidson
78 Mustang
67 F250ish
interesting. thanks for posting.
