1/2 ton camper special rims
I know there are wider 3/4 ton c/s rims but were there ever any wider 1/2 ton c/s rims,I found some 1/2 GM c/s rims on craigslist but wodering if Ford made any. I am in the process of converting my 66 F250 into a 1/2 ton and would love to have a pair if some were ever made.
- Dirty Offio
Re: 1/2 ton camper special rims
Um, did they make a 1/2 ton Camper Special? I thought that was a 3/4 ton package...possibly a 1 ton also, but I do not think I have ever seen an F-350 Bump with a Camper Special badge. I know I have never seen an F-100 Camper package.
Always looking to learn something new.
I do not know if you are trying to stay with stock rims...but if you want deeper rims, you can get brand new deep dish white spokes for a reasonable price, or find other wheels used (Craigslist or wrecking yard) that would work. I personally do not like to run stock wheels, my single F-100 has 10" wide Gambler II aluminum wheels on it. But if you are going down the restoration path, I wish you well.
Cheers.
Offio
Cheers.
Offio
When in doubt, hit the gas. It may not be the right answer, but at least it ends the suspense!!
The only substitute for Cubic Inches, is Cubic Money!
1967 F-100 swb "Varmit"
1968 F-250 4dr lwb "Beast"
1976 F-350 drw 460
1977 Club Wagon
1986 F-250 lwb
1976 F-350 drw 460
1977 Club Wagon
1986 F-250 lwb
I thought i read that a 1/2 camper special was made but I am also trying to find out if 4x4 rims are different.
- ToughOldFord
Yep, my '67 was an F100 Camper Special. Had regular 1/2 ton wheels though.
1969 F250 Ranger Camper Special. 390, NP435, 3:73s.
That government is best which governs least, because its people discipline themselves. -Thomas Jefferson
I am thinking I should have used a 73-9 9 inch and had the spring perches rewelded to fit my 66,the 67 to 72 9 inch looks too narrow in it.
I think the F100 CS was fairly stock as far as suspension and tires. Those were meant for the shells which
didn't weigh a whole lot compared to the bigger campers.
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
I put one of my broncos 8 inch wide rims with 31-10.5 tires and filled up the wheel well nicely so I ordered a pair of 8 inch rims with the same back spacing.
- Mancar1
I had a 1/2 ton CS.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- 3 Speed
A picture paints a thousand words:
What I like about the 67 F100 Camper Special is that the owner absolutely did not need any stinkin' right-hand mirror to see around a camper shell wider than his cab!
Now that is a brave trucker!
67 F101 Custom Cab longbed, 352 V8, 3 speed manual
