Steering wheel
67f100customcab
Steering wheel
Post by 67f100customcab »
I plan on installing a 78/79 tilt wheel automatic column in my 67 f100 will i be able to use the stock 67 wheel like the one below.
BobbyFord
Re: Steering wheel
Post by BobbyFord »
I believe the spline is the same but you'll have to trim the shaft to fit the horn assy.
Re: Steering wheel
As said by bobby. Just grind off the end of the shaft so the horn ring will go back on.
67f100customcab
Re: Steering wheel
Thanks i always thought the later padded horn looked cheap
FORDification
Site & Forum Admin
Site & Forum Admin
Re: Steering wheel
Post by FORDification »
While the steering wheel will physically fit the shaft, the steering wheel's hub is smaller in diameter than the '78-'79 tilt column's, so not only would you have an ugly gap where you could see down into the steering column, but the nubs on the bottom of the early bumpside wheel spokes will hit the wider column hub. Here are a couple shots taken when I was investigating this very thing for my truck, discovering that it wouldn't work.
