.....weapons of last resort-screw removal
BigRedTruck
Post by BigRedTruck »
I tried the penetrating oil.....i tried craftsman screw-out.....i tried craftsman screw-out with a reversible drill it has not worked these screws hold on engine covers and the engine to the frame on my motorcycle. my last thought was maybe the japanese reversed the screws so counter clockwise tightens. that turned out not to be true it would have been nice though. I do not know where to go from here. Two of my screws look like dog bowls. everytime I would get resistance it either messed up the drill and/or required me to speed up,then it would just break free and lose traction. short of using a explosive device what can be done?
69 F-100 2wd 360 cid C6
1970F250
Post by 1970F250 »
last resort = vice grips :thup:
binder56jd wrote: If you can't dazzle them with diamonds- baffle them with b------t
72hiboy4x4
Post by 72hiboy4x4 »
!. use a screw extractor/hammer driver. put a phillips head in the end, place it on the screw and whak it a couple times. worked all the time on my bikes when I was a kid. (recommended)
2. carefully cut a slot in the end of the screw for a flathead screwdriver, tap a large flathead screwdriver in the slot with a hammer. Now, while holding the screwdriver with vice-grips, turn the screwdriver and at the same time,hit the end with a hammer. easier with 2 people. (did that make sense?)
BigRedTruck
re: .....weapons of last resort-screw removal
most of these are recessed into the engine body. on one at least, there is hardly anything left of the head....its more like a rim and a hole hollowed out by about a 4th of a inch. I am unsure if i can cut anything. I have a 12 volt cordless drill and the standard set of screwdrivers and sockets. I have no idea what my dad may have. how would you cut a screw?
drill the head off. keep using larger bits until the head is gone.
1970F250
Post by 1970F250 »
you use a die grinder or a hack saw blade to cut the slot but if theres no head left that might not work. then what fordman said is the way to go.
BigRedTruck
well the screw extractor-spiral shank type worked.
mrung0wa
Post by mrung0wa »
I have a set of left-handed drill bits and I always try to use them first!
If those don't work I have a choice of either a 3/4" Impact wrench (forward or backwards it doesn't matter it will come off...) or a 20lb sledge hammer.
I like to have choices.
Lawrence 8)
BigRedTruck
i finally got them all out. but the cover still will not move. guess i'll drop 60 for the factory manual
binder56jd
Post by binder56jd »
oh no not the directions :lol: :lol: :lol: jd
now serving #235
BigRedTruck
Is there a special set for allens head stuff?
mrung0wa
Post by mrung0wa »
What are alien heads???
Lawrence 8)
BigRedTruck
get my terms mixed up...they were hex head
mrung0wa
Post by mrung0wa »
FYI: It's just like a "Phillips head" and "Cross head" screw or screwdriver. Mr. Phillips invented/patented the Cross head but unless you had worked out a deal with him (A long time ago) you couldn't use his name.
The "Allen head" and "Hex head" relationship has a similar history.
Just more useless triva...Worth the same as a free cup of coffee...
Lawrence 8)
