Mine has been working its rear bumper off for the past few weeks holding down my driveway....hopefully I can find some time soon to work on it
- SoCalRefuge
Took the wife and dog for ice cream and some country road cruising. Trucks not pretty but it runs strong and they love it.
- cstoyer
Refurbished my gage cluster by repainting the orange/red on the needles and gage face then installing it in a pick and grab bezel and clear plastic cluster cover. Just started my rebuild so as I take things off I'm fixing them so I'll be ready to put it back together after paint.
68 F250 4x4
- themoldfords
And then there were 2...
Picked up a parts truck over the weekend!
Tim
____________________________________________________________________
'69 F100 240, 3 spd (used to be column shift), '05 F150 wheels, cougar buckets, Hurst floor shifter, '78 discs, power steering and column
"Your responsibility to be ready for the fight never ends" - James Yeager
- 1970F250CS
Painted a few things (rear bumper,wheels,grill inserts). After a little wax, the original lacquer paint came out pretty nice.
I did nothing to my bump yet again today! Still trying to get the house and garage repaired and repainted after $19,000.00 worth of storm damage this summer! That sure does cut into the bump budget!!!!!
Retired and lovin' it!!!!!
Tomorrow replacing water pump gaskets and other misc items.
- Ranchero50
Refurbed my rear slider gaskets using parts from a newer Chevy work van. Rest of the story...
http://www.fordification.com/forum/view ... 06#p703506
changed my oil. mobile delvac 15w40, plus a wix filter filled to the top with stp zddp oil additive. also poured a oreillys carb cleaner additive into some 91 octane. stared at my exhaust and wished i could afford to get it finished right now. the neighbors aren't diggin the open headers
just put in my 3rd speedo cable in 8 or 9 years. chinese crap. i hosed the new one down completely with ballistol. speedo bouncy needle problem solved
Yesterday I changed out my rusty wheels for new ones bought from Summit Racing. Same style, white spoke. Today I am putting in new thermostat because, according to my gauge it doesn't get very hot. Either the gauge is way off, thermostat is stuck open, or there isn't a thermostat.
I found that there is a thermostat, one that is for 160*. I put in a 195* along with new hoses but I found that the old hoses don't quite fit the radiator. The PO used "sleeves" on the radiator end of the hoses to step them down to a smaller size. Kinda hokey, but I will be using them also, I am waiting for the silicone to dry so I can put them on.
I also need to repack the wheel bearings.
- popeyes71
Changed the oil on the old girl.
-Popeye-
1971 F-250 4x4 Highboy
still cant figure out this wiring grrrrrrrr.
Aurelio Landeros
1970 f100 240 I6 3.9L 1bl carb 4 speed light duty
- chazskinz
Researched some period correct parts. Got rims back from AWR and checking on tires. Waiting on parking brake cables so I can get the rear wheels on and get her off the jacks and start collecting stuff from inside to do during the winter months. That means refilling my supply of EVAPORUST and soaking parts! Love that stuff. Saved a ton of money with that. Taking inventory on parts I can offer for use by others. Got a lot of good "smalls" to offer.
Starting on the frame again today, hopefully get some more boxing done and cross-memebers
