back on the road
boots
back on the road
Post by boots »
got pretty much all the loose ends tied up today, took it for its first test drive in about 5 months. Bump steer is eliminated, steering is tight, everything works great. Now I have to get an alignment and its a daily driver. Im very happy with the way the radius arm mods turned out, and how great the new steering is. I got away without putting in a drop pitman arm :shh:
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
FORDification
Site & Forum Admin
Site & Forum Admin
re: back on the road
Post by FORDification »
I like it! Time will see how well it holds up on the street or off-road, but right now it looks good. You should take and post a few more shots from different angles, so we can check it out closer in the daylight. :D
...and you know? I'm almost thinking this would be an interesting and informative tutorial. You've been doing well with documenting your progress, so we should assemble all your updates onto a page, for others who might be considering something similar. I know the question on lifting a 2WD had come up numerous times.
boots
Post by boots »
thanks Keith, tommorow I will take some more pics for you guys. Over the next week I will get all my pictures together from the lift, and make some kind of write up. :D
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
heep70
Post by heep70 »
Looks great 8)
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
ivansgreat
Post by ivansgreat »
Nice. :rock: Now all you need is some bigger tires.
Ivan
1968 F100 2wd
302
spartman
Post by spartman »
That does look good.
Makes the truck look like a highboy.
boots
Post by boots »
I think the truck is pretty much exactly the same height as a highboy, because it has a 4" block in the back, just like the factory f250's. Soon im going to get rid of the block, and do a shackle flip. I want to run 35x12.50's, my buddy is going to give me his 4 old bf goodrich 35x12.50 tires, so I can check for rubbing issues, and all that other stuff.
here are some more pics
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
flyboy2610
Post by flyboy2610 »
Nice job! :clap: :clap:
I like your choice of paint color! Mine is going to be silver with a red interior.
1970F250
Post by 1970F250 »
:woohoo: :thup:
binder56jd wrote: If you can't dazzle them with diamonds- baffle them with b------t
460 crew
Post by 460 crew »
Looking really good!! I'm excited to see you on the road again.
