Gas tank 1970 bump.
Firefighter9103
Gas tank 1970 bump.
Post by Firefighter9103 »
Should I move gas tank to rear or leave behind seat. Really wanna keep original as possible but was wandering about gas smell in cab. ????????
HIO Silver
Re: Gas tank 1970 bump.
Post by HIO Silver »
It's your truck and your decision... how committed are you in keeping it "original"?
BobbyFord
Post by BobbyFord »
There isn't a market for these trucks so modified or original doesn't really affect the value. JMO.
Canonman67
Post by Canonman67 »
As long as you have the right gas cap you shouldn't have any smell in the cab unless you have a leak.
EDVSU
Post by EDVSU »
:yt:
I switched my stock cap for a new locking cap from LMC.
Wasn't that expensive, feels kinda cheapish but the only time I smell the fumes is during fill up.
Makes me feel better too knowing someone can't dump stuff in my tank or fill it up w/o the key. Highly recommend that step first. If you're still not satisfied you can check the tank relocation threads. A lot of good options on here. :2cents:
- Martin Gza.
calipilot227
Post by calipilot227 »
You could always install the rear mounted tank, and then drain and disconnect the in cab tank. It'll still look original, but you won't smell gas inside.
My Ford: 1970 F250 Camper Special (360, C6, 2WD, drums all around)
My Daily: 1998 Volvo S70 T5
"In the beginning, God made the light.
Shortly thereafter, God made three big mistakes.
The first mistake was called "Man." The second mistake was called "Wo-man."
And the third mistake was the invention of the poodle."
