Brake lights comming on and staying on.
Rustybones
Post by Rustybones »
I am having an issue with my 72 f250, when I park it the brake lights stay on, if I lift up on the petal they come off, only have the petal sag and come back on later. This started after the master cylinder and booster was replaced.
eggman918
Re: Brake lights comming on and staying on.
Post by eggman918 »
Two things I can think of first would be the rod length if it's too short it would cause it second is the brake light switch is adjustable to a some extent and the adjustment threads are plastic co it could have moved.
But if there is a lot of"play in the brake pedal you might try an adjustable rod between the pedal and master cylinder.
