Operation Spud...Restoration of my 1970 F250 4x4 in Honor of my Father.
Madman
Re: Operation Spud...Restoration of my 1970 F250 4x4 in Honor of my Father.
Post by Madman »
Looks sharp!
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
Slow weekend, got some painting in the cab done, but mainly got the Instrument Panel assembled.
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
A little update here. It is 38 days until my Rifle Bull Elk hunt, and it is time to prep NOW! So most likely I won't be updating or posting much for the next month or so, but if I am successful, I'll show some Rocky Mountain Scenery in the future!
2017 Ford Raptor
1975 Ford Bronco
Perkint
Re: Operation Spud...Pics being uploaded now...:)
Post by Perkint »
Madman wrote:Detailing the engine...
How did you paint the raised relief lines in the valve covers so well? The space between each line looks too narrow to mask off. Just curious.
Madman
Post by Madman »
I used a foam roller brush, sprayed the foam with the engine spray paint, and used light pressure to prevent the paint from flowing out of the foam too heavily. The little runs I got I used the satin black and sprayed it onto a small brush. hope that makes sense.
2017 Ford Raptor
1975 Ford Bronco
hfdco4
Post by hfdco4 »
Any updates?
:fr: FE390PC
Madman
Post by Madman »
hfdco4 wrote:Any updates?
Well, I successfully took a 5x5 Bull Elk during season, and should start back on the truck soon! Only update so far! :D
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
I've finally got back to working on the truck, here I've installed the new firewall pad and rebuilt pedal assembly.
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
And here is the painless wiring kit starting to be installed. I figured I'd better wire it before installing the steering assembly.
2017 Ford Raptor
1975 Ford Bronco
popeyes71
Post by popeyes71 »
Oh yes, the long and tedious process of wiring up a vehicle, it's all about patience. What did you think of the fitment and quality of the firewall insulating pad?
-Popeye-
1971 F-250 4x4 Highboy
Madman
Post by Madman »
popeyes71 wrote:Oh yes, the long and tedious process of wiring up a vehicle, it's all about patience. What did you think of the fitment and quality of the firewall insulating pad?
So far so good, need a second hand to install the heater core, so I'll no more in about a week. Things line up "close" but not always perfectly.
2017 Ford Raptor
1975 Ford Bronco
Ranchero50
Post by Ranchero50 »
Wiring with the factory harness was pretty easy. :)
Madman
Post by Madman »
Got the steering shafts all rebuilt and installed, heater box is in, and routed the heater control cables, which was a bit of a bitch at times.
Question? Is there a better way to attach photos? I have been using Photobucket but it can be a bit of a bear at times. I see others attaching really detailed, large, and nice photos that do not rely on photobucket. How are you lads doing that?
2017 Ford Raptor
1975 Ford Bronco
Madman
Post by Madman »
Ok...got the new painless wiring harness routed (relatively), firewall pad is installed, and have wired up most of the switches. I got the new inner fenders laid out and am giving them a heavy coat of heavy rust resistant Eastwood Paint. Ordered the new seals to install the inner fenders, and a new Champion 3 row aluminum radiator is on the way. No pics as the wiring is kinda lame to try and look at.... :wink:
2017 Ford Raptor
1975 Ford Bronco
Lone Ranger
Post by Lone Ranger »
Your trucks coming right along looks real good. That motor is sweet! It's going to pop right out of the engine bay when it's in there!
Kyle
