Got most of the fuel injection system wired up, but can't fire her up (still awaiting my radiator). The system is pretty slick, but there is a ton of extra wires. Engine bay looks busy!
2017 Ford Raptor
1975 Ford Bronco
Verified the LED worked in the dash with the battery charger, hooked up the speedo cable and installed the dash. The only cab wiring left is the radio!
2017 Ford Raptor
1975 Ford Bronco
Got the radiator and shroud installed. I've added coolant so once I get off the overly oppressive work run of being on shift or traveling for the next 20 days straight I should get her running!
2017 Ford Raptor
1975 Ford Bronco
Here I've attached the Fuel Injection Fuel Reservoir and Electric Fuel Pump Assembly. If anyone uses the Edelbrock system on their truck you may want to zone in on this, options for mounting are limited if you don't modify the inner fenders.
This air filter looks nice with the set up.
2017 Ford Raptor
1975 Ford Bronco
Lone Ranger wrote:That's a nice looking setup! When do you expect to hear it run?
After today I am on almost a twenty day work run, 10 days of shift work, and 7 days of training with travel to Phoenix then another couple of days of shifts before I get ONE day off, so it will most likely be mid April,
2017 Ford Raptor
1975 Ford Bronco
A little more progress......Got the other inner fender installed......
.....Fabricated most of my exhaust system.....
......and installed the dash pad!
2017 Ford Raptor
1975 Ford Bronco
