67' longbed build
Re: 67' longbed build
Tonight i ordered up a cpl more things. New starter. I know. i know. New steering coupler. New battery tray. New gaskets. All top end baby!
Tomorrow or right now im gonna order and new distributor and stage 8 grade.locking header bolts. Cost as much as the distributor. Lol.
Than all ill need are those rebuild.heads.
D
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
- DuckRyder
New stuff is fun.
Might as well do a cam if you’re that far into it (a mild one).
- Manny
Just caught back up on this thread. Looking good That thing will run great when its not got a destroyed exhaust valve. Wow that was bad.
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
Looking good man! Love that Holley your putting on there. You might want to paint your new brake master cylinder. The cast part rusts quick. Great progress dude!
Kyle
Kyle
thanks guys.
duckryder I don't know a lot about engines. I had to have the old man buddy from work help me out/give me enough confidence just to get the top end off and apart.
Im guessing a mild cam is meaning upgrade the shaft middle spin thing that spins the fan and rotates all the cylinders up and down... ? I could post a google pic but im pretty sure I know wat ur talking about.
new battery tray, steer coupler, top end complete fel pro gasket set and remy starter all showed up yesterday.
New stuff is great. All I feel ive been doing lately on this build is buying new parts and compiling em.
Checked on the heads today. Notta. Notta thing done to em yet. Which is okay for now... Seems ill be getting a new set of c8 heads cuz he or his buddy has some sitting on a shelf that prob need less work than mine. LOL
Id prefer the ones that came with the motor just for fit and function but we will see how that turns out. Don't bother me either way.
Dropped off my intake today to get sand blasted. Not ideal but should work for me. Gonna paint it high temp ford blue!
Holly is awesome lone ranger. Ebay $200. new. GET ONE!
Working me like a dog at work so sunday will be my next day off. Get to do my moms acura rotors that day. whooohhhhooooooo.
keep at it guys. thanks for looking.
-d
-d
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
last major things I still need to buy and gather are
HEI distributor and matching coil
stage 8 locking header bolts
rebuilt heads
chrome dress up kit (not needed right away....)
rebuilt heads
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
- Manny
Camshaft is the item in the middle of the block that operated the valves not the crankshaft that carries the belt pulley. The camshaft is behind the water pump behind the timing cover. A improved cam hold the valves open longer and opens them more to increase the air and fuel in and the exhaust out to increase the power. Hopefully you get it all together soon that will be great to get it running for you again.
Today i got my intake back from sandblast. I hit it with blue high temp 2 coats and 2 coats.of clear laquer finish. Hope it stands up.
Got.my battery tray in place. Old.one.came.out in.2 pieces
:0
I got my new steering.coupler on and the bolt that tightens the collar.piece.around the steering box gear just strips out. I tried the old bolt and that stripped. Uhhhg.
Also.got my heater box.out all the way and blower.motor disconnected from it.
Tomorrow i.might try and finalize all the steering wheel and such mumbo jumbo and put the new starter on.
Also tomorrow i may get to the new tranny.pan, bolts, gasket, and shifter linkage hooked up.
Ill try and upload.some new pics.
D
:0
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
- Manny
I dont know how. Photobucket is being a jerk.
D
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Testing. 1....2....
Looks like this boat will stay a float. Ill grab a pic of all the stuff im talking about to get u all caught up.
This is the steering coupler im working with. Said on the box to have the main bolt at 32lbs torque spec and the two on the sides at 11lbs... well mine just stripped out. Maybe i wasnt supposed to take out all the way when i put it on? Does it even need it? The steering.coloum and.steer box kinda sandwhich it in. I.dont see it coming off unless.i role the truck!
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Hei distributor is supposed to show up today. All im waiting on are the heads. I can clean stuff up but dont really know what ill need as far as odds and ends or problems ill run into when re assembling it all. Basically nuts and bolts. I got some 3/8" header bolts but they look too small. I dont have my heads to see. Lol. It is 2min away buy ehhhh. I dont wanna rush anyone.
I need some metal work done in the cab before i wanna spray and clean all that up.
Where im at.
Thanks
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Ran to.mclendons not.to long ago and got my starter bolts. Grade 5.
Cant wait to get this thing done and move on to working on the inside of the cab more
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Looks good Dude! Gonna be sweet when you get it back together. Looks like your choke cable or throttle cable is sticking in one of your cylinders careful she don't scratch.
Kyle
Kyle
