Air Compressor??
- mrung0wa
re: Air Compressor??
Yeah I think about 75 miles or is that Kilometers?
I always forget, Damn , Metric crap!
Now that's 1 if by land, 2 if by sea, I think?
Lawrence
Lawrence
- binder56jd
the duty cycle would be on whatever elec. motor you chose to power it- jd
now serving #235
now serving #235
- mrung0wa
If you don't already have the motor then here are a couple tips: Go 220v-240v if you can,because you'll get twice the power at half the cost! Get a "Shunt" Motor. The moment that they turn on your at Maximum torque! You'll want to go with a 220v-240v motor for sure.
Lawrence
Lawrence
- mrung0wa
Wow really?
I think that you can inflate a beach ball with that, but It'll have to be one of the smaller one's
Balls I mean...
Lawrence
Balls I mean...
Lawrence
- spartman
Found some info at this site:
http://www.therangerstation.com/tech_li ... rdAir.html
According to them the yorks have a CFM Rating of 4.0 CFM @ 90 PSI.
Not enough cfm to run a sandblaster.
Found another site that shows that if you run a york at 2000 rpm you will get 7.3 CFM out of it.
http://www.jedi.com/obiwan/jeep/yorkair.html
- binder56jd
well since an engine could be running anywhere from 1500 -4000 rpm you could probably do some pulley arrangement to run it closer to 3000 rpm and get more out of it safely- don't forget the pressure relief valve- that'd be UGLY-jd
now serving #235
now serving #235
- mrung0wa
Okay let me get this straight here.
If you get 7.3 CFM @ 2,000 RPM, then shouldn't you get 21.9 CFM @ 6,000 RPM and 29.2 CFM @ 8,000 RPM!
Oh man this is awesome! 36.5 CFM @ 10,000 RPM
The Formula 1 cars this season switched to V8's from V10's.
The Redline on the V10's was about 19,000 RPM's. The V8's have been Redlining at around 22,000 to 23,000 RPM's.
Theoretically then If you were to install one of those York compressors on an F1 car you get a Whopping 87.6 CFM @ 24,000 RPM's!!!
Lawrence
Lawrence
- binder56jd
put a 10 in. pulley on a 2000 rpm motor- that oughta do it
now serving #235
now serving #235
well, i do not remember my CFM but the compressor i have in the garage is a 6.5hp, 150psi max, 110v witha 30 gal tank. I do like my cutoff switch for the motor, so i don't have to unplug it when i am done. I also ran PVC pipe through out the garage, where i have six outlets, so i don't have to drag a hose from one end of the garage to the other end.
- mrung0wa
Yup!
I always hated doing that...I even installed Hose reels in the front and the back of my garage.
- binder56jd
it's called "ugly versus enterprise"-jd
now serving #235
now serving #235
