Can you help identify this truck??
chutchin
Post by chutchin »
Hi everyone. A friend of mine directed me to the resources on this site to identify a truck that has come across my radar.
I am wondering about the exact year of the truck. I have used the VIN decoder and my hangup (based on how I read it) was the VIN shows a 2wd but this truck is 4wd. Maybe I am just looking at it wrong. I am trying to zero in on the correct parts to purchase for brake line repair. It does have power brakes. Attached are a few pics I could get.
Thanks for any help anyone can give.
1972hiboy
Re: Can you help identify this truck??
Post by 1972hiboy »
Its not unheard of to have a body swapped or a door swapped on from another truck over time.....
Rich
Dont eat yellow snow.....
DuckRyder
Post by DuckRyder »
Can you find a VIN stamped on the frame?
What engine is in the truck?
Any indication of the original color somewhere other than the door with the ID plate? What color is the interior?
FWIW a quick decode makes that as a early 68 production... 2 WD F100 with Harbor Blue Paint and Blue Vinyl Interior, 360...
chutchin
Post by chutchin »
Oh absolutely I know it's possible. I just wanted to get some opinions before I proceeded.
Thanks
chutchin
Post by chutchin »
I was told it was a 70's model...I know I come across as a retard, but there were just too many different kits in the LMC catalog.
The interior is blue. It has a 360.
1972hiboy
Post by 1972hiboy »
Its a made in March of 1968 truck, from right here in San Jose ca. comes up as a half ton 2wd truck with a 360.
http://fordification.com/tech/VIN68.htm
Rich
Bill Ramsey
Post by Bill Ramsey »
It could be a 2wd truck with front axle added..
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
1962 Fairlane 500 Sports Coupe
VW Sandrails
Honda ATC's
36' Diesel Pusher for roughing it.
DuckRyder
Post by DuckRyder »
I was thinking F100 4x4 were only short beds? (I could easily be wrong)
The grills inserts are made from expanded metal?
My decode agrees with 1972hiboy but the grill surround that is there do not look like 68 parts to me.
We need more investigation (and pictures)
1) Is there an id number on the top of either frame rail near the axle?
2) Is there any sign of frame modification (splicing, crossmember removal, adding the straight front axle)?
3) is there evidence that the body or parts of it was another color?
Does the transmission match the ID plate?
More pictures please.
See also http://www.fordification.com/tech/67-72ID_01.htm this will help nail it down too.
My initial impression is it is a collection of parts from at least two trucks, but we need more information.
JoshT
Post by JoshT »
You've definitely got a mutt there. 68 door tag (and body?), 70+ grill and valance, 2wd door tag with a 4wd front axle. Frame vin is definitely the next thing I'd be looking for, see if it matches the door tag or the 4wd.
DuckRyder there were definitely factory F100 4x4 long beds, I've got one.
cstoyer
Post by cstoyer »
VIN stamped on the frame is what you need to find as this will tell you a lot about the truck. Might have been a simple door swap without the door tag being changed.
Passenger side frame rail is where you will find the VIN. One in the engine bay area the other on top of the rail under the cab.
cstoyer
68 F250 4x4
chutchin
Post by chutchin »
SOLVED
Found the VIN on the frame. Does come back to what the truck is (I believe). F11YKN8235 Says its a 72 4WD with a 360.
Thanks for the help.
