72 f250 4x4 old blue
Jsimon
Re: 72 f250 4x4 old blue
Post by Jsimon »
Question- here is my rocker and a pillar.
On the left is an angle piece I added to the replacement inner rocker to make the lines look better. Do I need to do continuous spot welds or the few tacks you can see ok? Should I do seam sealer next then primer?
1972 f250 4x4 390 4speed
jzjames
Post by jzjames »
Alright :thup:
Jsimon
Post by Jsimon »
One step forward and two back. I tackled a piece of the cab that I had been avoiding. Here's what I had to work with
to make this
But I decided to pull the engine and get a better look at things and found this
At least to bent pushrods on each side. Looks like I'll be searching for a cheap 390 crank since I'll have everything apart.
Jsimon
Post by Jsimon »
Picked up a "new" engine, came with this gem:
Has a 390 2bbl that runs good. Bought the car for $400, pulled the motor and scrapped it. Just have to swap my oil pan,pickup tube, and motor mounts (glad I read about grabbing the crank bolt with the stud).
hfdco4
Post by hfdco4 »
Nice score!
:fr: FE390PC
geradr4
Post by geradr4 »
Great find. Looking forward to seeing more updates.
hfdco4
Post by hfdco4 »
Any updates?
:fr: FE390PC
Jsimon
Post by Jsimon »
Broke off 5 out of 8 upper manifold bolts on the 390, 2 of them came off with vice grips, 3 drilled and tapped. Have done a lot to the cab but have a long way to go. Here is my new floor at the rear cab mounts
Next step is making inner cab corners.
hfdco4
Post by hfdco4 »
Wow! Now that's a lot of good fabrication there. Very nice progress.
:fr: FE390PC
sargentrs
Post by sargentrs »
Nice work!
Jsimon
Post by Jsimon »
Finished my inner cab corners, just need to tack them in place
Thought you would get a kick out of my "sheet metal brake" I sandwich it in my hydraulic press and beat it down. Had to break out the big hammer for the 16ga metal!
jzjames
Post by jzjames »
Metal shapin’ :thup:
hfdco4
Post by hfdco4 »
Brute metal bender!
:fr: FE390PC
Jsimon
Post by Jsimon »
I'd be embarrassed to say how many hours (beers) I have in this rocker panel. New top and back side and a few inches of the curved part. Aftermarket rockers weren't even close.
hfdco4
Post by hfdco4 »
Well, I say it looks good.
:fr: FE390PC
