71 f100 Firewall Wiring Connections/Destinations?
71EVOLUTION
Post by 71EVOLUTION »
Good Evening All:
I acquired a 71 f100 shortbed 4x4 that was completely dismantled as the previous owner was going to paint the inside and out, but lost interest & parts sat in buckets for years. I've assembled a majority of the truck, but I am left with several wiring connections that I don't know where they go to.
1. Ther is a grommet from the driver side firewall to the engine bay that has 4 wires that coalesce into a single female quick attach grommet. I believe that one wire goes to the coil, another to the oil temperature sending unit and it appears that the other two bceome one as there are only 3 wire connections on the other 'outlet' side of that quic-connect. I am missing that male connection that attaches to it leading to the engine etc & I cannot find one anywhere to purchase. Can anyone identify where these wires go?
-There is a large "pink" wire that goes alongside a brown wire that appears to feed into the same socket
-There is a Yellow Wire with thin Red Stripe
-There is a Red Wire with a thin White Stripe
(image attached)
For the life of me I cannot find a photo or an image as to where these wires go; and I'd really like to locate & buy a connection with the wires to the engine etc if anyone knows of?
Any help would be Greatly Appreciated.
basketcase0302
Re: 71 f100 Firewall Wiring Connections/Destinations?
Post by basketcase0302 »
You can use the 72' diagram to reliably wire that harness, (look at the distributor on the diagram and you'll find the wires location you need). :wink:
Here's another good page to bookmark for future reference to help with electrical:
http://www.fordification.com/tech/wirin ... -chart.gif
And I'd highly advise buying one of these as it's worth it's weight in gold when your broke down on the side of the road with a wiring issue! :thup:
https://www.ebay.com/itm/1971-71-Ford-F ... SwcBhWXgS-
sargentrs
Post by sargentrs »
Good reply, Jeff, and that diagram is awesome! 71EVOLUTION, I replied in your other post with a source for the harness.
basketcase0302
Thanks Randy, the laminated one that I had was kept rolled up in the glove box and bailed me out more than once on the road! :D
