PaPa's 69 F100 Explorer Coyote 10R80 swap
Venomous duck
Re: PaPa's 69 F100 Explorer
Post by Venomous duck »
More markings found
Venomous duck
This is on the bottom side.
Venomous duck
On to sand blasting.
Venomous duck
Powdercoated in semi gloss black.
Last edited by Venomous duck on Thu Feb 11, 2021 10:09 pm, edited 1 time in total.
Venomous duck
I used a large file then a sander to clean up the machined surfaces. Doing this caused the loss of the machine marks but I had to get rid of the pits.
Venomous duck
Finished housing.
hfdco4
Post by hfdco4 »
Dam dude, you are really making progress. I also pulled my springs apart and cleaned them up. I know they were coated with some kind of black coating. I painted mine with a Grafite Paint called EZ-Slide. I didn't find any insulators between the leafs, but they also could have been apart before.
:fr: FE390PC
Venomous duck
I am really confused about the silver paint I found. I hope someone can comment on that. Someone painted on the black, turned out the third member had been painted as well, more to come on that. I really considered the EZ slide but wound up going with the spring liners. I am going to try to post more tomorrow, more to show on the rear end.
Venomous duck
Next up is the third member, chunk, pumpkin or the thing that goes inside the housing. The third member had been painted with a spray can Black. This was a surprise as it meant someone had been inside it before. I also noticed black spray paint on the leaf springs that I did not understand. I really searched my memory for an answer. As I stated early on this truck has been in the family since new. Because I am really the only one to work on it since the early 80's I knew this must have been done early in it's life. Finally it came to me. When I was a kid probably around 10 yrs old (this must have been around 74) I remember visiting my grandparents. My Grandfather whom is the original owner was telling my parents about a kid taking the truck for a joy ride, (all keys were always in the ignition on the farm). I don't know who it was but I think it was a second cousin or something. Anyway he got it stuck in the pasture and somehow destroyed the rear end. Not an easy thing to do to a 9 inch. It was never spoken of again. The good thing for me is that the poor paint job preserved the marking underneath. The paint came off with little effort.
Venomous duck
Disassembly started
Venomous duck
Turns out it has the correct Ford 3.25 ratio gear set, but Timken bearings.
Venomous duck
More disassembly
Venomous duck
Empty Case
Venomous duck
New parts
Venomous duck
This is a 2.75 gear set I thought I would see if I could clean up.
