Ford f100 1970 resto. Nearly done!
- hfdco4
Re: Ford f100 1970 resto. Nearly done!
Nice progress. Nice work on the pass thru mount.
FE390PC
FE390PC
I am happy with the progress that you had with this build. I can't wait to see the result of your hard work.
- hfdco4
So did you finish? Are you out and driving this nice ride?
FE390PC
FE390PC
It is street legal again and i have taken it oit for a short drive
But i think my alternator is not strong enough or breaking down.
Still need to install the djm loweing kit for the rear.
Oil filter got damaged by the previous steering setup and started leaking.
Still having a lot of coolant leaks by hose clamps
I bought a two post lift, so i should be able to fix and do everything soon!
Keep you posted
Keep you posted
Ford f100 '70 302
Audi S6 4.0 tfsi
BMW 525i '90 Turbo (project 500rwhp)
Full resto:
http://fordification.com/forum/viewtopi ... &start=135
Audi S6 4.0 tfsi
Full resto:
- hfdco4
Keep at it, leaks are always fun the fix. Did you do the 3G Alternator upgrade? Get one from a 90's Taurus, 130amp and one wire.
FE390PC
FE390PC
Thanks for the tip, I'll have a look if they have any taurus around here!
Still have the 'original' alternator
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
Audi S6 4.0 tfsi
Full resto:
It seems like my alternator idy working but my gauge is not giving the right current.
Anyway i lowered the rear with a djm kit!
Lowered about 3", inwas hoping for the full 4" but it is looking good!
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
Audi S6 4.0 tfsi
Full resto:
Walk around
https://youtu.be/XpGOMpFPS9Y
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
Audi S6 4.0 tfsi
Full resto:
- MAK
- Location: Georgia, Blairsville - Florida, Flagler Beach
I just scrolled through the ten pages of your awesome build Very nice work!
You should be very proud and I know how happy you will be driving and showing it off.
Gives me hope, encouragement and makes me not feel quite as bad about the slow progress on mine.
Thanks Mak, it was definitely a long journey!
still some things to do, but i guess that will be normal with an old car
good luck on your build
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
Audi S6 4.0 tfsi
Full resto:
- 67mann
See that the future owner is checking his tire pressure
- JWW
What a great thread. You have done some awesome work. Thanks for sharing.
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
2004 F150 Crew Cab
Haha yup, only 1.5 years old, but a big smile whenever he is in it!67mann wrote: See that the future owner is checking his tire pressure
ThanksJWW wrote:What a great thread. You have done some awesome work. Thanks for sharing.
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
Audi S6 4.0 tfsi
Full resto:
Time for some winter maintenance.
Change steer
Add rollpan
New 1 wire alternator
Line lock
Fix leaks
Change oil and filter
Make a switch on the park brake and use the 'brake pressure' light to light up when 'active'
Take out some unused wires and clean up more
Align wheels
Adjust timing
And most important, complete overhaul transmission
Anyway see what I can do in the next days
[image]
afbeelding maken [/image]
Change steer
Add rollpan
Line lock
Fix leaks
Align wheels
Adjust timing
[image]
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
Audi S6 4.0 tfsi
Full resto:
- hfdco4
That is a tight fit on the driver's side when on the lift!
FE390PC
FE390PC
