Torque Wrench Question???
When you are going to tighten a bolt to a specific torque setting what is the correct start point i.e. should the bolt be finger tight before you start torqing?or what?Thanks
re: Torque Wrench Question???
thats what I do. they won't register anything till you get a certain amount of resistance.
69 F-100 2wd 360 cid C6
- heep70
Start there and then I increase in increments of 10lb if there is a more then one bolt or nut. ie head bolts
ei, ei, oooooooooooooooo
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- flyboy2610
And if you are using a 'click' type torque wrench, be sure to set it back to 0 when you are doen. You sould not store those wrenches with tension on the spring.
