****NEW PROJECT****
- Ford390pwr
****NEW PROJECT****
I have just started a new project today! Visit the links below and follow my progress!
re: ****NEW PROJECT****
Wow...that looks like an awesome start for a project. I was checking out your pics and noticed that of the pics sent to you by the seller, there's a shot of the driver's side that appears to show some rust along the roof driprails. Is that area rusty or just the way the pic looks?
I'll be watching for your updates!
- Ford390pwr
Re: re: ****NEW PROJECT****
That is what you see from a vehichle that has sat for a while in the Northwest! Actually, it was just some debris from a tree, and when I got there to pick up the truck, most of that was gone from lifting the cab with his boom truck.FORDification wrote:Is that area rusty or just the way the pic looks?
I wish I could of gotten some pics from when we loaded it on the flatbed, because this boom truck made easy work of lifting that cab! The problem was we got down there at about 5:15 in the evening and it was just too dark!
I just spent the better part of the afternoon removing the clip and lifting the cab from my flatbed! Boy was that ever scary!
This was the look on my face when I finally got the right angle to support the weight with my cherry picker
You lifted that Crewcab with a cherry-picker?? I definitely wish I could have seen that. You must have a good-sized unit ...errr.....cherry picker!Ford390pwr wrote:...This was the look on my face when I finally got the right angle to support the weight with my cherry picker
I know some people have asked on the forums before how to lift a cab off a truck and I've always suggested that they use a cherrypicker, and wished I had a photo to show them. The next time you do a site update, you should reattach the hoist and get a shot, just so people can have the visual to try to mock up something similar.
- Ford390pwr
I definetley was a trial and error process! I wanted to get some pics, but once I got it clear of the flatbed, I just wanted to get it on the ground quick. I am sure that the Cherry picker would work better on a regular cab because it would be easier to balance.FORDification wrote:You lifted that Crewcab with a cherry-picker?? I definitely wish I could have seen that. You must have a good-sized unit ...errr.....cherry picker!Ford390pwr wrote:...This was the look on my face when I finally got the right angle to support the weight with my cherry picker
I will try to get some pics as I will be rearranging everything now that it is on the ground.
- Ford390pwr
I just added some pictures of what the cab looked like after a little bit of cleaning was done. I am trying to get some more done tonight and will keep you all up to date!
- 72hiboy4x4
now this is the way to lift a cab off the frame!
By the way,if this cab looks similar, its the same cab, I sold it last summer.
- Ford390pwr
So did Heath make a profit from it or did he have other plans???72hiboy4x4 wrote:now this is the way to lift a cab off the frame!
Also, please let me know if you have any other pics of the trucks previous life!
So let me see if I'm understanding this correctly....you sold the cab and then bought it back? Cool!
You method of lifting the cab off is pretty similar to how I did it with several while parting out some trucks:
http://www.fordification.com/images/69cabremoval2.jpg
- Ford390pwr
Keith, you are confused... Let me explain!FORDification wrote:So let me see if I'm understanding this correctly....you sold the cab and then bought it back? Cool!
72hiboy4x4 lives in Kelso WA, which is close to Portland. He sold the cab to the guy that I purchased it from.
So the guy I got it from just held on to it for a little while before he sold it to me!
Does this make sense now???
Ah, OK. Gotcha.
- 72hiboy4x4
I posted a couple more pics of the boom truck lifting the cab off the chassis. check my gallery. bill, i sent you an Email, also.
- Ironbelly67
Wow. Lots of sweet steel, not much bad rust at all from waht I can see.
*1967 F 250+390+NP435
*1967 F 100+352+C6
*1972 F 100+351+C?
1970 D 100
1953 IHC R-110 USMC+MVPA
1950 IHC R 110 Panel
1936 HighCab 1Ton
2004 Ford Expidition XLT
*FORD tops the list
*1967 F 100+352+C6
*1972 F 100+351+C?
1970 D 100
1936 HighCab 1Ton
*FORD tops the list
