All else has failed.....
- wildcard
But I've lost the instructions. I have a volt/dwell/rpm meter and cant remember where to hook up the leads (one black, one green) to check the Dwell and RPMs. About all Iremember is it is an old Craftsman. Could get the model # if I put on my glasses . Any help would be appreciated. BTW, it's a 300 I6, with points and condenser.
- 72hiboy4x4
- 390Nut
re: All else has failed.....
does it look kinda like this?
craftsman meter
I've got the instructions for it, if you want I can scan it and email it to you
craftsman meter
`69 F100 390 4spd driver
- wildcard
Thats prretty much it, only it has just a small black and a small red gator clip. And it doesn;t have the dial. Only the slide selector in the vertical position. The scales appear the same.If you could send those to me I'd sure be grateful. I can probably figure it out with a little jolt of the old memory. Thanks
- 390Nut
Never seen one like that, wierd. These instructions probably wont help much, but I'll dig them out later and get it scanned in this evening. Use the email button below to email me, and don't forget to type in your email address so I can send you the files. Probably be .doc files, but I'll see how they turn out when scanned, and may have to save them as .jpg to get them to be readable (not all that familiar with my scanner )
- 68F250
Hi! Normally dwell meters connect to the coil negative (-) post. But before you do that there should be some kind of adjustment to zero out the meter when you have the test leads shorted together.
Barry
- 390Nut
Glad to help.
