Auto to Manual Swap Out For A 1970/1977
I just got my 1970 body on my 1977 F250 frame job done... Now I am going to make it into a manual. Right now I have a 302 and a C6. I just got a 84' 4 speed. I got all the clutch pedal stuff from a 1971 F250. Do I need to get the clutch linkage for a 1977 F250??? Or can I use what I got? I got a steering colum from a 1972 F250. So that is taken care of. Now the tranni I just got is a 4x4. Later I am going to make my 1970/1977 swap out into a foru wheel drive monster. So I am going to go ahead a install the four speed with the transfer case. That away it is already set up. I got a greeeeeeat buy on a dana 70 front end, with the gears to match my dana 60 rear end. So if anyone could give me some advise on my project monster, I would be thankful.
- 72hiboy4x4
- boots
72hiboy4x4 wrote:I didn't know they made a Dana 70 front axle.
Yep, I believe its the same as a dana 60, but just has a bigger ring gear.
junkman johnnie, is your dana 70 a 35 spline, or 23?
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- heep70
re: Auto to Manual Swap Out For A 1970/1977
If its the same as the D60 then wouldn't have either 35 or 30 spline?
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- 72hiboy4x4
I just did a quick search for info on the Dana 70 front axle. I'm not turning up a single mention anywhere. Anyone know what they came in originally, or have more info on these? I have a D-70 dually rear in my truck, and will someday upgrade to what was going to be a D-60, but if I can get a D-70 front, thats what will go in it!
- heep70
I am with you on its existance. I have not heard of such and animal.
Greg
- heep70
Well Mike, I did some searching and came up with a closed knuckle version and a kingpin style. Not alot of info about the specs though. Looks like the closed knuckle came in the 60 era and king pin in the late 90s. Closed knuckle being weaker then a D60 and the king pin being noted as strong or stronger then the 14 bolt. These are D70 frontends I am talking about.
Yep, something new learned today. I thought I knew it all
Greg
- 72hiboy4x4
late 90's eh? means I will never be able to afford it then!
back to searching for someone who doesn't know what a D-60 front is worth/going for.
And I thought you knew it all too!
where did you find that info?
- heep70
Greg
- heep70
Did you pull the axle and count the splines? From what I have ran into on Ford F250 D60s is they are usually 30 spline inners and outers. F350 had some 35 spline inners and all 30 spline outers. I know back then you couldn't get a 35 spline outers for the Ford D60. But you could for the Chevy D60 because of the military uses. I am sure they make 35 spline stubs now, but if not you can use the chevy stub just need to shorten in a bit.
Greg
