That would of been way more simple.flyboy2610 wrote:I gave Frodo the shock treatment as well, but there is an easier way than jacking up the rear end: http://www.fordification.com/forum/view ... 50#p622628
A tip to help the next time you need to do this job.
1968-f250 wrote:Earlier today my dad and I started working on the cab mounts, if you can even call them cab mounts anymore. We made up a pattern for the pass. side, and also started working on patterns for the kick board and the parts of the floor pans that need replacing. There is going to be a lot of fabricating and welding, but it its worth it.
I never thought of that, i just assumed that they were home made. I'm just glad the body shop that put them in just bolted the mounts on. That would have been a nightmare to get them off if they were welded in place.Thoselook like the cab mounts JC Whitney used to sell in the 80s I bought a set for my 72 when I was in highschool.
Thank you! I can't wait until I'm crossing that line!hfdco4 wrote:Great work, the finish line is in sight.
One tool that is quite useful is a thin wall 2-9/16 socket for doing the bearing lock nut. A regular 2-9/16 socket won't fit as the walls are too thick.1968-f250 wrote:Thank you! I can't wait until I'm crossing that line!hfdco4 wrote:Great work, the finish line is in sight.![]()
I'm currently working on the last of the mechanicals, which is the brakes. Lets just say it's not that fun of a job on an f250 with the way the rear axle is set up. I'll try to find some time to throw in some pictures and give a more thorough update soon.
Last summer I had an issue with the drum on the passenger side locking up so I had to pull the drum off to see what the problem was. My dad and I ended up fabbing a socket that would fit the lock nut and it worked real slick. I"ll take a picture of it and post it on here. I also stumbled across robroy's thread and it helped a lot. I'm actually almost finished with the brake rebuild. All I have left to do is put new seals in the front drums/repack bearings, install the new master cylinder, bleed/adjust breaks and adjust the parking brake.flyboy2610 wrote:One tool that is quite useful is a thin wall 2-9/16 socket for doing the bearing lock nut. A regular 2-9/16 socket won't fit as the walls are too thick.1968-f250 wrote:Thank you! I can't wait until I'm crossing that line!hfdco4 wrote:Great work, the finish line is in sight.![]()
Here is one on eBay:
http://www.ebay.com/itm/KD-2463-2-9-16- ... 70&vxp=mtr
robroy did a good write up of his brake job on a '72 F250. It may have some helpful tips:
http://www.fordification.com/forum/view ... r+adjuster
Thanks for the support! I'll try to get some pics posted tonight if I have enough time. I can't wait for the truck to be sitting on all fours again. Hopefully this weekend...Amazing, I just spent the last hour reading your entire thread!
Keep up the good work, looking forward to more pics.
