I took the cab for the f250 (which is a 69 f100 cab) off the f100 by jacking it up the body away from the frame as much as I could. With some good tree stumps supporting the body I lowered the frame down, with no tires on, was able to slide the frame out by reversing it. It was actually just a 1 man job, and then I to put it on truck I had a few buddies help.FordTruck wrote:How did you lift the cab off by your self?
becuse i'm working on that same project of cab swapping.
new '68 4x4! Project - Update 9/28
- boots
Re: re: new '68 4x4! Project - Update 6/12 : Dana 60 front
Ethan
67 f100 - 4"lift - cut fenders - 36 TSL's
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
http://www.fordification.com/forum/view ... 835#136835
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- boots
Just to let everyone know.
Ive been slowly collecting parts for my front dana 60 and still work at competition fabrications. I just have to buy gears, kingpins and some other misc stuff then I can start putting the front end together. Ill post pics when I have something done other than just new parts.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
I've really enjoied watching the progress of this build can't wait for more updates.
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
- boots
Got a set of 39.5" TSL's online and picked them up in Minnesota on friday with my dad. Was about a 6 hour drive from here. I have still been buying parts for the dana 60 front. I just graduated high school so I dont have a kickass income yet.
I just received Yukon 5.13 gears , and the overhaul kit. My boss is showing me how to install gears in a rear dana 60 on a customers car tomorrow, and then the next day I can do mine in the shop.
The fenders will get trimmed, and the truck will sit about an inch taller when its all done.
Still have to get/do:
- Kingpins
- Driveshafts
- U bolts
- Front Dana 60 hubs
- 1 ton yokes for the t-case
- fix rear axle (a few Bolts broke that connect the external hub/shaft broke to the axle)
- Install rear disc brakes
- Mount seats as well as some other small stuff...
Pics:
- Kingpins
- Driveshafts
- U bolts
Pics:
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- boots
No the motor does not leak, I just spilled when I pulled the diff cover.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
re: new '68 4x4! Project - Update 7/28: 39.5" Swamper T
Looks Sweet!!
I got this year and next year till i graduate high school
. So lucky
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
- RedneckTexan
- rjewkes
if both of the trims on the wells look good and you shave far enough not to use please save 'em?
- boots
Ill check the condition tomorrow since i really have not messed much with the body, but yes I do plan to trim the fenders, and I am willing to sell you the chrome.rjewkes wrote:if both of the trims on the wells look good and you shave far enough not to use please save 'em?
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- AK F100
LOOKS KICK A$$. My bump is a little truck. The daily driver is a little bigger, 97 F-350 CrewCab Diesel runnin 37's. Keep up the good work.
GPBFD Pyro Maniac
Daily Driver: 1974 F100 4x4 (ride'n on 8-Luggers) Build in progress
1997 F-350 Crew Cab 4x4, 7.3L Diesel SOLD
Pile-O-Parts: 1968 F100 - 2WD Shorty SOLD
Looking for a new project 57-60 Ford Truck
That looks so sick! Nice work cant wait to see it done.
Dan
'69 F350 Crew Cab
'69 F350 Crew Cab
- boots
Thanks guys, I will have updates soon. I have a ton of parts that need to go on. Within a week or 2 I should be able to roll it out of the garage for the 1st time in 2 years!
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- boots
Re: new '68 4x4! Project - Update 9/28
Well I have not done much lately but work work work, and not on the truck that is. But I have all the parts to finish the front 60, and finally finished drilling out all the broken bolts in the rear hub. This upcoming week im bringing the dana 60 home from work with the new 5.13 gears in it, Then I will assemble. I have some pics to hold the picture gurus over though. Custom fabricated high steer arm, and a bunch of other stuff.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- HRDROKN
Ha.... some of that stuff brings back recent memories! Looking good!boots wrote:Well I have not done much lately but work work work, and not on the truck that is. But I have all the parts to finish the front 60, and finally finished drilling out all the broken bolts in the rear hub. This upcoming week im bringing the dana 60 home from work with the new 5.13 gears in it, Then I will assemble. I have some pics to hold the picture gurus over though. Custom fabricated high steer arm, and a bunch of other stuff.
Any Updates??
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
