bumps with lowered altitude!! (lots of great custom bumps!!)
- guhfluh
Re: bumps with lowered altitude!! (lots of great custom bumps!!)
'67 F-250 Crew 2wd 300ci, T-170/RTS/TOD 4-speed overdrive
'96 Dodge Ram ECLB CTD
'99 Dodge Neon ACR 2dr - 10.64@130 (Sold)
'05 Infinity G35 Sedan
Here is my lowered bump, it was a '72 longbed that is now a '69 short.
It has a jag xj6 IFS, Explorer 8.8 rear, frame is Z'd front and back and fully boxed
Riding on 20's w/ 30" tall fronts and 32" tall rears, GM ls 6.0l & 4L80e, A/C and Cruise control
joelb114 wrote:Here is my lowered bump, it was a '72 longbed that is now a '69 short.
That is beautiful! Is that a static drop or do you have air?
I gotta try pretty hard to scrape it on something...
That is great. Did you have to raise the truck bed floor?joelb114 wrote:Thank You, It is static, and has plenty of clearance for daily driving,
Yeah, bed floor raised 6 inches...
- Craigerf100
Not sure if my truck qualifies to be here
3"+ front via explorer springs w/ one coil cut.
1" rear
Front and rear addco swaybars
Looks great I think!!
Before with explorer springs w/no coils cut.
1" rear
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
My Build:
http://www.fordification.com/forum/view ... &sk=t&sd=a
My Build:
Tubular mustang II with larger K719 ball joints, dropped spindles, QA1 coil overs with 700lbs springs. Rear notch, axle flip and front hanger flip.
235/55/20 on 20x8 front / 30.5 tall ..........285/50/20 on 20x8 rear / 31.5 tall
Build thread:
http://www.ford-trucks.com/forums/12052 ... build.html
Hey guys!
I have a 69 F100 Long Bed that I want to do the Axle over leaf spring swap. Would I have to C Notch the frame to do this?
if you want it to ride right you will have to. I'm about to start mine today.Jody86 wrote:Hey guys!
- BobbyFord
Yes or you'll have very limited suspension travel.Jody86 wrote:Hey guys!
Crown suspension has a good c-notch kit I just used. Plasma cutter or cutting wheel and a good drill and you can have done in an uninterrupted afternoon.
http://www.crownsuspension.com/lowering ... notch-kit/
Has anyone done an axle flip with the comfort ride springs?
