Alternator Upgrade
re: Alternator Upgrade
When I get to that point on my project I'm sure I'll be upgrading as well, and will definitely do a tutorial. That'll be a while though, I'm sure.
on the big body Ford alt conversion really the only bracket you need to change is the adjustment side, and in most causes you don't need to do it. and if you do you just cut and weld to the angle you need or pull it of the car you got the alt off in most causes changing the belt length fixes the problem. and also the aluminum spacer behind the alternator on the pivot side some times needs to be cut down a little bit. I do this swap allot and there really is nothing to it.
if you go to a parts counter and ask for the ford 100 amp alt with a v belt
pulley theres only one the can give you now with that said it the guy behide the counter looks at you funny and ask what year just make one up like a 1980 Lincon/Cougar with a 351W and a/c should work.
ford only made one big body alt.
WHAT ?
Again... need some specifics... year, make, model... part number? Any rewiring necessary? Put us together a tutorial Leadfoot.
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
ok ok 79 351W T-Bird/cougar?or you favorite full size ford car auto with ac and a 100amp alt
or
UAP napa pt# 2133021 at $90.99 and a $55.00 core charge in US funds and while you are there ask for a new alternator pig tale and a voltage reg. then bolt it on you truck. Done
or UAP pt#BSH AL573X @$134.00 (alt)
UAP pt#MPEVR140SB @ $13.99 (voltage reg)
or
WHAT ?
there is another direct bolt on using your old alt and a kit you can get for $44.95 you can convert ant external regulated 35 ta 65 amp ford 1G small body to 105 amp.
the kit comes with every thing you need Pt # HO-7013 from quick start auto Ph# 1-616-785-7990 or http://www.alternatorparts.com/ford_alt ... e_kits.htm
WHAT ?
- basketcase0302
Leadfoot,
Good stuff again
just saved me a couple of hundred to power the 20 KC lights I'll be adding to the one ton
Where do I send your refund to
Basketcase
Good stuff again
Basketcase
I'm going to assume the factory alternator on the bumpsides is the 1G small body? If memory serves me the regulator is on the passenger side of the radiator core support right? So they are already externally regulated.
Patrick
Patrick
Chevrolet
Yes you will have a small body 1G alternator thats externally regulated on you truck. and yes the regulator is mounted on the right side of your rad support normally under your right horn, beside the battery.
WHAT ?
