Homade sandblaster
hossw71SportC.
Post by hossw71SportC. »
Well i screwed that up. I was trying to post some better pictures of the sandblaster. but ether I am too dumb or it just won't work. Said somthing about no bmp images??
oh well
Get-R-Done
71 F100 Sport Custom
99 F250 Powerstroke
hossw71SportC.
re: Homade sandblaster
Mybe this time?
Get-R-Done
99 F250 Powerstroke
spartman
Post by spartman »
Interesting
hossw71SportC.
And here is the gun.
Get-R-Done
99 F250 Powerstroke
hossw71SportC.
one more
Get-R-Done
99 F250 Powerstroke
spartman
Post by spartman »
So is the tip a standard tip or something unique?
Also it looks like to operate it you need to turn two air valves right?
hossw71SportC.
The tip is a ceramic one like normal but it is inside a union that is drilled out!
There are acually 3 valves.
one for ain thats coming in
one for air to the gun
one for bottom of tank for sand to gun
oh and one at the gun
4 valves
Get-R-Done
99 F250 Powerstroke
spartman
Post by spartman »
So this is supposed to be a better setup then or just more complicated?
spartman
Post by spartman »
I see.
Might just have to pony up the 5 bucks and give it a try.
hossw71SportC.
I could be nice and give ya a copy of mine?
Get-R-Done
99 F250 Powerstroke
spartman
Post by spartman »
You could if you wanted to.
I know you ponied up the 5 bucks for it.
If you want some sort of compensation please let me know.
Thank you
hossw71SportC.
Hell, the info that guys like you give is worth more than that.
But one problem, can't attach it to the post. Its a pdf file and it says that they are not aloud to be attached??
Help :hmm: :? [/url]
Get-R-Done
99 F250 Powerstroke
spartman
Post by spartman »
Not sure.
Maybe you could put it into your photo gallary?
Maybe put it up on photbucket or something and then link it in a post also?
