are all 4wds "high boys"
4x4 & Off-road Forum Archives
Moderator: Doug Comer
460 crew
Post by 460 crew »
How wide are the F150 4x4 springs Keith?
FORDification
Site & Forum Admin
Site & Forum Admin
re: are all 4wds "high boys"
Post by FORDification »
ummmm....I don't know, I didn't measure them. :D But the next time I'm out there I will, as well as the other trucks.
rjewkes
Post by rjewkes »
Am i gonna nned a set of those blocks for a 69 4x4?
ICEMAN6166
Re: re: are all 4wds "high boys"
Post by ICEMAN6166 »
460 crew wrote:It must be so cold up there they shrunk and your tape mesure was warm :lol: Did the 3in tall block you removed have the bumpstop provision on it? And they were 2.25in wide?
yep.stock with the factory u-bolts when i took them out in the summertime
.actually other than my 66 it was the first f250 i had seen with only the 3" blocks but now i will have to look at the 68 and 70 i have here too.
on the 72, i took the 60 and 3" blocks out, put in a posi 70 and the 4" blocks.
also put a 65 f350 cab and holmes 460 wrecker on the back.
http://www.fordtruk.com/forums/album_pi ... user_id=26
averagef250
Post by averagef250 »
It's always possible someone swapped under some 3" blocks. You didn't happen to read the casting numbers on the blocks did you?
I think the dentside F-150 4x4 springs are 3" wide.
ICEMAN6166
averagef250 wrote:It's always possible someone swapped under some 3" blocks. You didn't happen to read the casting numbers on the blocks did you?
i was looking for the blocks the other day for just that reason.when i find them i am going look for the #.
i do not think they were changed ever, the u bolts were the ford ones , not aftermarket or made in a shop.
