Rust removal
67F250CS
re: Rust removal
Post by 67F250CS »
http://www.thepontiactransampage.com/rust.html
Try this one.
I coundnt the other link to work but this one did just fine. :D
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
BCOOLEY
re: Rust removal
Post by BCOOLEY »
OK call me crazy but I like to try new things.
Do you guys think this would work on a hood!
I have a kiddy pool big enough to use. the hood I have has alot of surface rust and It would be wasier to put it in the pool and leave it wile I do
other things to the truck! Any thoughts?
FORD BUILT EM TUFF WE BUILD EM BETTER!!
jor
re: Rust removal
Post by jor »
I don't see why that wouldn't work. We have to have some photos of that, for sure.
jor
Docholiday72tx
re: Rust removal
Post by Docholiday72tx »
That kiddie pool and hood got me to thinking.....my grand pa has a water trough out at the farm for cattle that holds probably 4 to 500 gallons of water.
He hasn't used it in years. I bet I could almost get a cab in there. I don't have any big parts that are loose right now, but as soon as I do....I think I may be going to the farm. :evil:
If it ain't broke....oh wait a minute....it is.
68F100
re: Rust removal
Post by 68F100 »
1968 F-100 2wd Short bed style side
-302,C4,3.50 9"
1977 F-150 Ranger XLT 2wd Long bed
-400M,C6,3.25 9"
1981 F-100 2wd Long bed
-460,C6, 3.? 9"
derrabls
re: Rust removal
Post by derrabls »
68F100, Seeing your pics just make me very happy. Since I can't get a sandblaster I'll just dunk anything and everything I can fit into a tub. Awesome. Thanks for the pics.
heep70
re: Rust removal
Post by heep70 »
Man :eek: , I am going to show my neighbor this. He owns a cheby. :D
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
flyboy2610
re: Rust removal
Post by flyboy2610 »
Looks like I need to go get me a battery charger!
68F100
re: Rust removal
Post by 68F100 »
Like I said, it takes a little effort after you take it out. But nothing like you would have to do without this method.
I took a drill with a wire wheel and just cleaned up the black stuff that's left over when it's done.
Another tip: take a wire brush and knock off any crud/grease before you put it in. Won't hurt anything if you don't, but it seems like it works faster if you knock off the crud first.
-302,C4,3.50 9"
-400M,C6,3.25 9"
-460,C6, 3.? 9"
Docholiday72tx
re: Rust removal
I knew it worked well on small parts, but I hadn't tried anything as big as a radius arm yet.
How long did you leave the radius arm in?
Did you do the I beams too?
I'm tickeled that you guys are enjoying this tip.
Doc :D
Jonathan Rickman
re: Rust removal
Post by Jonathan Rickman »
Will this also remove old paint? I'm not talking about just yanking a fender off and tossing it in...errr...well yes I am! :D
Docholiday72tx
re: Rust removal
Honestly.....I don't know. I did small parts like a brake booster bracket. It did have a little paint on it, and I mean very little when I did this...and it took it off.
Sounds like it may be time for an experiment. :evil:
greenbank
re: Rust removal
Post by greenbank »
From what I understand, it won't touch old paint. It's strictly rust from ferric metals (as I recall, you don't want aluminum in there, either).
1968 F250 Ranger Camper Special
-- 360, AT, PS, PB, disks
-- See Goldie
68F100
re: Rust removal
Post by 68F100 »
I don't know about the paint deal because none of the parts I've done had paint on them.
I don't think I would try aluminum either.
I left the radius arm in all day while I was at work, so I don't know how long it actually took. I haven't done the I beams. I don't have a tub big enough.
-302,C4,3.50 9"
-400M,C6,3.25 9"
-460,C6, 3.? 9"
