update on 68-
- dablack00
Re: update on 68-
I like your home made heat shield. Make sure you use good big wires too. My 460 has a hard time starting sometimes when it is hot and I know it is the wires to the starter getting hot.
- 68swb
Re: update on 68-
i used a big worm clamp to hold the sheild to the starter and also bolted it to the bellhousing.... so far it is working better then before.... still need to set the timing with my light.... probley this weekend.
"I got this"
68 swb 429ci 3spd
69 lwb f250 360 4spd
75 VW superbeetle
79 F250 4X4 supercab 400 4spd
07 Fusion
08 Focus 35mpg
68 swb 429ci 3spd
75 VW superbeetle
07 Fusion
08 Focus 35mpg
- iamthewreckingcrew
Re: update on 68-
Looks like you stripped the factory paint off the headers. How did you go about doing that? Also, did you re-coat them with something?
I have the same headers and started stripping them with an abrasive wheel, but I can't get all the nooks and crannies.
68 F-100 Short Box 2wd
302/c4/3.50
81 F-100 Long Box 2wd
460/c6/3.00
92 F-150 Lariat 4wd
302/auto couldn't go wrong for $500
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
