Frame swap that has turned into a hole lot more
HRDROKN
re: Frame swap that has turned into a hole lot more
Post by HRDROKN »
Nice looking truck!
:thup:
td
Post by td »
hey prostreetjim,
have you considered trimming you coils while you have it all apart ? mabe 1 round, that wouldn't give you any camber issues and i think the rake it would add to your stance would look killer!!
wt4speed#2
Re: re: Frame swap that has turned into a hole lot more
Post by wt4speed#2 »
td wrote:hey prostreetjim,
X2
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
'69 F-100 "Stepper"(currently in a bigillion pieces )
wt's ride
thebucket
prostreetjim
Post by prostreetjim »
I will have to wait and see how the new setup is going to look, Those old spings that were on it were mighty tired. new big block on it now and the rear is setup a little different. I'm going to try and get a full day to work on the thing, this weekend maybe. Sure want to git-r-done and on the road before winter hits. I going to have to pick up the pace, just too may projects around the house to do, nah! trucks comes first don't it :D
td
Post by td »
thats right Jim! truck before house choirs. :thup: :thup:
