67 Front end clean up!
Re: 67 Front end clean up!
i say it was oil. but i cant prove it. it could have been water. but if it wasnt loosing either fluid and not showing anything but white smoke out of the breather. it was probably oil. is could have been water. have the head magnifluxed to check for cracks.
oh, i will. there was alot of oil on the engine when i got it. the valve cover wasn't ver tight as well as some of the other bolts on the engine.
- dolinick
Well it seemed to run good but there was a little vibration. The transmission never would go into 2nd and 1st is such a low "granny" gear. It was fun to drive. I'm glad it seems not to be anything serious. Anyway have fun with the project.
Dan
Dan
2003 7.3L F250
1968 F500 Utility Truck
yikes, after removing the dash pad i decided to take out the seat as well. man after i removed the rotted floor mat, dimes, pennies, paper, toy soldiers, chip bag, dirt, screws, bolts, washers, wire and what ever else some of the stuff was on the floor, this is what i discovered.
http://i180.photobucket.com/albums/x115 ... 1248474956
http://i180.photobucket.com/albums/x115 ... 1248475000
what a bummer . good thing is that i got a welder for my birthday. need to practice first.
- fireguywtc
Thats too bad, looks like you are about to get more intimate with your new truck and its cab.
Bill
1970 F-250 4x4 highboy ranger 390 V8, 4spd
2012 F-350 PSD FX4 LWB CC lariat, white
http://www.fordification.com/galleries/ ... hp?uid=602
"If you want to judge a person's true character, give them power."
i know, you should see the crap i dumped out of my gas tank as well.
- dablack00
Now aren't you glad you didn't end up spending all that coin at my place.
Glad to see you are really getting into the project.
Austin
Austin
i bet the oil was coming out from under the valve cover and landing on the exhaust and making smoke that came up through the floor like dolnick said it was coming from.
plans have changed for the 67. since the sheetmetal such as doors, bed and fenders are better than the 71, it will now be giving those parts to the 71 since the 71 has a good cab. i guess you can call it the 671.
