Eh, thats not all bad. Wait till you have to pull the cab off the truck to do any major engine work on a 6.4L. The 6.0 are cake to work on, once you learn the little tricks to everything. The new 6.7L is even worse for stuff under the hood, it uses a water to air intercooler instead of an air to air, and it takes up a good chunk of space.
I'm an apprentice diesel tech at a ford dealership, so sometimes i get stuck with the work no one else wants to do.
Glad only one diesel in my driveway!!!
Re: Glad only one diesel in my driveway!!!
Ex Ford diesel dealership senior master tech (6 years)
Current bmw level 4 tech.
1972 Ford F100 Stepside - 302, forged TRW flat tops, performer 289 intake, edelbrock 600 cfm carb, CV IFS swap, 4.10 LSD disc 8.8 , AOD 4 speed auto. Currently 5 years in the making.
- Joshpow
Stay motorcraft glows. Had autolites in mine that previous owner put in. They didnt last. Mines doing great now though.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
real diesels dont use glow plugs
67 F100, 300(Offy intake, Edelbrock 500, 274*/.518" lift cam, heddder, duraspark & Summit CD ign), 4spd, power steering swap, front disc and hydroboost.
08 VW R32
increase diesel fuel rate site:
http://www.freewebs.com/nevrenufhp/index.htm
08 VW R32
- 1982 flareside
No real diesel has glow plugs in virgina it is colder then california.
Jeremy
I was referring to the bigger ones, like medium duty, and heavy duty not having glow plugs. A DT466 (for example)can start down to 0* without assistance from pre-heaters or ether.
08 VW R32
08 VW R32
Ive got a Cat3406b and it will start on its own at -10* without being pluging it in, but its hard on a diesel to do that and dosent make good since not to plug it in a coulple hours before starting.nevrenufhp wrote:I was referring to the bigger ones, like medium duty, and heavy duty not having glow plugs. A DT466 (for example)can start down to 0* without assistance from pre-heaters or ether.
- jbohall001
Does my moms Q7 count? Its a diesel. I wouldnt dare try to change the glowplugs myself, if it even has any.. I dont know
Vi hilser til Day
Vi hilser sønner Day
Vi hilser the Night og hennes døtre
Se på oss nå, med myke og ømme øyne
Velsign oss som sitter her
Vi hilser gudene
Vi hilser på gudinnene
Hilsen til deg; hellige Earth
Gi oss en gave av kunnskap og visdom
og la oss få hender som kan helbrede.
Vi hilser gudene
- Joshpow
I tell ya what. I know it aint a big bad diesel, but the ol stroke has been a good one so far. Mine would fire without too but I appreciate my expensive starter more than treat it like that.
Josh
71 F-100 Custom SWB
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- AlleyCat
As long as you don't complain, at least too much, you'll always have work.71fordkid wrote:
Clay
