The real reason why they are called bumps.
- BobbyFord
Re: The real reason why they are called bumps.
Hey, I was just funnin'. I don't want to wind up in that "Why the attitude?" thread
Power steering will self bleed. Just turn the wheel lock to lock a few times. If it's not leaking and you're getting air, it would be that the pump is bad. When checking the fluid level, always check while running.Caseys71 wrote:Side note: Power-steering that needs re-bled is a lot harder to use than manual steering. Changed the hose a little while back and bled the power-steering pump, then I get in the truck this afternoon to drive down to the field we hunt at to put out some corn and check the trail cam, power-steering was pretty much non-existent when the truck wasn't rolling
. Now I've either got another small leak in the PS I didn't see, or somehow the air showed back up in the system, either way time to re-bleed it
- Bumpside Collector
Hit that darn latch almost every time I work on a bump.
CHEESE?!?
Running:
2012 Ford Focus SE hatchback
2007 F-150 XLT Supercrew 4.6 Auto
1972 F-350 Flatbed 360 2V 4 speed
Not Running:
1967 F-100 Ranger Short Bed
1970 F-100 Ranger Long Bed
1972 F-100 Ranger XLT long Bed
1972 F-350 Really long dump flatbed parts truck
1981 F-250 Custom Long Bed (Parting out now)
- 1972hiboy
Now thats funny! Only because I know when that hood goes up that my hinges sag so I always tell myself " dont hit your head" but yesterday of course I 'Bumped" it on that darn latch. Cheers to that!
Rich
Dont eat yellow snow.....
- Caseys71
BobbyFord wrote:Hey, I was just funnin'. I don't want to wind up in that "Why the attitude?" thread
Casey
- Caseys71
You are correct ;however, the way I understand it when you get a large amount of air in the PS pump the only/quickest way to get it out is by opening the bleeder valve on the back of the pump and running a line from it back into the top of the pump. I went with your method the first time around and it worked fine though. I checked on it last night and got the leak straightened out for the final time, hadn't even seen the leakRacer Z wrote:Power steering will self bleed. Just turn the wheel lock to lock a few times. If it's not leaking and you're getting air, it would be that the pump is bad. When checking the fluid level, always check while running.Caseys71 wrote:Side note: Power-steering that needs re-bled is a lot harder to use than manual steering. Changed the hose a little while back and bled the power-steering pump, then I get in the truck this afternoon to drive down to the field we hunt at to put out some corn and check the trail cam, power-steering was pretty much non-existent when the truck wasn't rolling
Casey
- hdpusher
One advantage of being short is you don't hit your head on the hood latch as often.
67 Chevy II 302 sbc
67 Ford F350 Motor home
68 Ford F100 long bed (Sold
78 CJ5
03 Dodge Cummins
78 CJ5
03 Dodge Cummins
hdpusher wrote:One advantage of being short is you don't hit your head on the hood latch as often.
Bobby is good with the zingers. And subtle too. Seriously, I bump my head everytime I finish working anywhere near the middle of the engine. When I self-satisfiedly straighten up and smile admiring my work... Bump!
I am an outspoken person. I will not be quiet to make you happy.
- FLATBEDFORD
Never. Maybe because the F350 sits a little taller on its 16" wheels and bigger tires?
My Photo Gallery
My Photo Gallery
FLATBEDFORD wrote:Never. Maybe because the F350 sits a little taller on its 16" wheels and bigger tires?
Even that doesn't save me. Maybe new hood hinges would help out my F-350 but I think I'd still manage to find that latch!
CHEESE?!?
Running:
Not Running:
