If you had 400.00 to spend on your truck?
Re: If you had 400.00 to spend on your truck?
insulation, carpet, anti rattle kit
72 F-250 custom.
69 F-100 custom cab
AKA 71-F-250-SC-72-F-250C
69 F-100 custom cab
- dolinick
I am currently getting all new brakes including master cylinder, replacing intake/exhaust manifold gaskets and hopefully rebuilding/replacing the carburetor. Maybe this is going to cost a little more than $400.00.
2003 7.3L F250
1968 F500 Utility Truck
dash pad and floor kit
If I had $400 to spend I'd haul my wrecked 93 F150 supercab I got from my dad to the frame shop. IF I had to spend it on my 71 I'd get my seat covered.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- FLATBEDFORD
Re-arch the rear springs.
My Photo Gallery
My Photo Gallery
- Bumpside Collector
New valve cover and intake gaskets. Headers and gaskets. Dash pad. A couple of tanks of gas. I have too many things I need or would like to do.
CHEESE?!?
Running:
2012 Ford Focus SE hatchback
2007 F-150 XLT Supercrew 4.6 Auto
1972 F-350 Flatbed 360 2V 4 speed
Not Running:
1967 F-100 Ranger Short Bed
1970 F-100 Ranger Long Bed
1972 F-100 Ranger XLT long Bed
1972 F-350 Really long dump flatbed parts truck
1981 F-250 Custom Long Bed (Parting out now)
Paint and supplies. Nothing fancy, just want the same colors thats already on it
- Caseys71
$400? I'd go with shocks and bushings to get my front suspension up to par with the fresh rear suspension. Then I'd spend the rest on sandpaper and primer so I can swap hoods with the parts truck and start body work then my truck would be road ready for me just not finished
Casey
a racerback (cab fairing) if i could find one,, does anyone make one
FLATBEDFORD, why do you want to re-arch the springs? Some welding/spring shops up here won't do that anymore because it takes away from the spring integrity. What we do is place another leaf under the stack and get new U bolts made up. The spring shop should do that all for you.
I did that to my Edsel rears and it looks as straight as it did new.
I spent $400 on a truck today but it wasn't the Merc.
A lifter was collapsing in the 345 I installed in my '64 International 1100A. The big problem was, I bought all 16 lifters from NAPA and if I would have bought them directly from International I could have saved $260.
- FLATBEDFORD
The spring shop that I talked to said they would re-arch and add a leaf plus bushings and U-bolts for about $400. These guys have been around forever and said nothing about concerns about spring integrity.
My Photo Gallery
My Photo Gallery
- ccryder2011
floor shifter,shocks,tires
remember the key is to start what you finish....
....happy cruising...
1967 f-100 sb,mine
2007 subararu wrx,son#1
2003 mitsubishi eclipse,son#2
2007 mercedes E 350,wifes
1967 f-100 sb,mine
- Joshpow
Front brakes from 73 up, lower by cutting springs, and install my trans!!!
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
71 F-100 Custom SWB
02 F-250 Stroke
- Mancar1
Change out my seat. or maybe manifold/4V.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- F100builder
Machine work for my 390 block for which I already have the rebuild kit. I also have an extra C6 and a new kit for it too! I'm looking to do a full powertrain swap this year sometime.
Patrick
