Sea Foam....
- woods
Re: Sea Foam....
Tastes bad too
- sublimer
Re: Sea Foam....
You know on the front it says...woods wrote:Tastes bad too
HARMFUL OR FATAL IF SWALLOWED.
...right
1968 Ford F-100
240cid (3.9L) Inline 6
3-speed on the Floor
2-tone Blacks & White
Custom Homemade Headliner
Moveable Speakers
Moveable Speakers
- 70_F100
Re: Sea Foam....
Sort of like the Red Lobster commercial.woods wrote:Tastes bad too
"I Sea Foam Differently"...
That's not an oil leak
That's SWEAT from all that HORSEPOWER!!
Re: Sea Foam....
put it in your coffee...not straight...good a.m. octane booster
- Bumpside Collector
Re: Sea Foam....
So how does sea foam work out for cleaning out the crankcase? Is there something else you can use in the crankcase to clean it up?
CHEESE?!?
Running:
2012 Ford Focus SE hatchback
2007 F-150 XLT Supercrew 4.6 Auto
1972 F-350 Flatbed 360 2V 4 speed
Not Running:
1967 F-100 Ranger Short Bed
1970 F-100 Ranger Long Bed
1972 F-100 Ranger XLT long Bed
1972 F-350 Really long dump flatbed parts truck
1981 F-250 Custom Long Bed (Parting out now)
- woods
Re: Sea Foam....
A million years ago, back when non detergent oils were common. A lot of folks would drain a couple quarts of oil out, add kerosene to it, let it idle for a while and drain it. I would not do this. Really, if you just change your oil relatively soon a few times, it will clean it.
- Ranchero50
Re: Sea Foam....
woods wrote:A million years ago, back when non detergent oils were common. A lot of folks would drain a couple quarts of oil out, add kerosene to it, let it idle for a while and drain it. I would not do this. Really, if you just change your oil relatively soon a few times, it will clean it.
Oh yeah, the Quaker Sate moments when you pull the intake off and the whole valley is so full of crud that it looks like the bottom of the intake. I used to hate those days...
Jamie
- woods
Re: Sea Foam....
Man, I once pulled off a valve cover and the crud inside has actually taken the shape of the cover, with just some grooves wore in it from the rocker arms moving up and down.
