72 crew cab cummins
smokey3215
Re: 72 ford crew cab
Post by smokey3215 »
heres the last few
fomocoguy
Post by fomocoguy »
That's one looooong bump. :lol: Nice progress! Keep it up! :thup:
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
1972hiboy
Post by 1972hiboy »
Yeah you are really moving on that thing......Great thread....I just sealed the deal today on a 72 crewcab special. Great minds must think alike because I was brainstorming going the exact route your taking making it four wheel drive and using the dodge dana 60. I will be sure to revert back to thins thread to see how you did things. may i ask why the ford super duty springs vs factory f350 springs on the rear end? what springs did you use in the front? what did it end up taking to get the dodge 60 under the truck and steering?? :D
Rich
Dont eat yellow snow.....
smokey3215
I used the superduty springs in the rear just so they would match the front liftwise. They are procomp 4 in lift springs front and back. To get the dodge dana 60 to work you have to notch the pass side spring pack to fit the spring pad other than that build a front crossmember and swing shackels. You can see i had to bend these because the dodge 60 sits like 1/2 wider on each side. For the steering i used a1978 cheby k20 drag link and rereamed the steering arms the ford one needs to be bigger and the dodge one i made so the drag link connects to the top not the bottom.By the way the reamer is 7deg. taper big $$$ for one but i love tools.If you need to know anything else let me know also i have more pics i could post so you could see some things even better. I sounds worse than it is took me like 3hrs to do that includes taking the old front end off.
smokey3215
i weigh all my options and it was way easer to get a dodge front 60. We have a truck night by me and those guys seem to have all the ford 60s sucked up. as fo shaving the springs i only had to take a 1/8 off i put the 60 on my mill and shaved alittle off the side of the housing otherwise i would have had to take 1/4 or more off the springs. the pads in the superduty springs wear out quickso it prob wont have time to crack.
smokey3215
I got some more done on the truck. I converted the dana 70 rear drums to disks. hopefully the weather will hold out and i can get some other stuff done before it gets bad otherwise it tranny transfercase and engine rebuild time.
smokey3215
last one
zakt
Post by zakt »
:thup: :pop:
1972 Ford F350 crewcab
1972hiboy
Post by 1972hiboy »
:yt: :pop:
Rich
smokey3215
i am on the quest to get some parts together to get my driveline rebuilt. Ill have some new pics real soon.
basketcase0302
Post by basketcase0302 »
smokey3215 on Fri Nov 18, 2011 9:43 pm
Highly reccommend 1350 series stuff for this! I had the rude awakening when I built my driveline that someone had scabbed 1/2 ton crap into my F-350! :eek:
smokey3215
oh no 1350 here i am going 1410 even if i have to have a yoke made for it. by the way anyone know where to get a 10 spline 1410 yoke. I have seen them i kick myself for not buying them then.
smokey3215
Well i finally got some time to work on my engine for the 72. I tore it down completely for a rebuild thank god i did. Rod bearings were shot but the crank miced out good so i have to run the rods to the machine shop to have them press new wrist pin bearings. Ill keep posing as i have pics.
smokey3215
heres the pics of the oring of the block
smokey3215
heres the rest
