FUEL
1970 Hi-Boy
Location: Middle Tenessee/Northern Wisconsin/wherever else I may roam to try and make a buck.
Re: FUEL
Post by 1970 Hi-Boy »
BRUTUS_T_HOG wrote:
EDIT: you can readjust your carburetor to run correctly on ethanol fuel, you just need to use the corresponding jets to richen the mixture 10%
Thanks, I'll keep that in mind if I get to where I can not find straight gasoline.
1970 F250 Sport Custom 4x4 360 V8, otherwise known as the Hi Boy, and a Harley-Davidson.
1953 Lincoln SA200 portable welder with a 4 cylinder 1941 Continental F162 engine.
"If you think you can do a thing or think you can't do a thing, you're right." Henry Ford
SmoothJ69
Re: FUEL
Post by SmoothJ69 »
one of my motorcycle buddies just sent me this,list of gas stations that don't use ethanol gas: http://pure-gas.org/
1970 Hi-Boy
Re: FUEL
Thanks SmoothJ69, that should help out a lot of folks.
adrianspeeder
Re: FUEL
Post by adrianspeeder »
Had to run new line in the boat, but otherwise haven't had any problems with any of the equipment or trucks.
Adrianspeeder
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
