Oxygen sensor.
Donnie
Re: Oxygen sensor.
Post by Donnie »
Hi, I'm comin' in late on this one.......are you guy's using the 02 sensor to just read your fuel mix?
Understand that the sensor range is from 0 voltage to 1 volt..........so the size, length & gauge of your wire is to be factored into your equation.
The 02 sensor was designed to read 02 present in the exhaust stream & feed data to the processor along with 5 other sensors so the mix could be at optimum at all times......So I gather some after mkt co. has dezined this unit to tell you what your fuel mix is & not to control it.?????
I can see a carbed engine in a FE driving this sensor crazy....they are very sensitive to carbon build up & thus an false reading????
Am I reading this thread correctly..........Donnie
