May I have advice on new wheels and tires for #50?
robroy
Re: May I have advice on new wheels and tires for #50?
Post by robroy »
Thanks so much for replying Robert!
DuckRyder wrote:I know this is a fairly common swap, But I don't know how common the front disc are...
Yeah, 'good point.
DuckRyder wrote:I'd personally not be too comfortable with that clearance, you'll have some movement in the wheel bearings and perhaps some flex in the wheel itself while turning.
Thanks Robert.
While poking around I had the feeling that I should probably try to measure the clearance for-real, since it's hard to show such a thing in photos clearly.
The piece of wire that I managed to run around the wheel's inner circumference (through the tight clearance spots) was about 3/16" thick. It kind of had to pass through at an angle around the tightest spots, but it did pass through. Maybe this still isn't enough though.
DuckRyder wrote:If it is still up in the air and bolted on try putting some force against it by hand and see whats up...
I wish I'd thought of this. I actually put the normal wheels back on and buttoned the whole thing up yesterday afternoon. But I'll do whatever it takes to get it right, including another trial fit; the trouble is, I think I could exert only 0.05% of the force that the wheel will be under during normal operation.
Thanks very much Robert!
Ranchero50
Post by Ranchero50 »
Wow, I was sure they wouldn't fit... Wonder if it's just the dually pattern that changed or if yours are off something 'special' built that spec'd that pattern.
In other news while changing the oil on mine I found a big dog knot on the inside of my passenger front tire. Really makes me think I should figure out something for a spare and some way to change it.
robroy
Post by robroy »
Thanks for replying Jamie.
Ranchero50 wrote:Wow, I was sure they wouldn't fit... Wonder if it's just the dually pattern that changed or if yours are off something 'special' built that spec'd that pattern.
Yeah, I dunno. This yard appears to have a vast outdoor yard behind the building where customers go, with car-sized shelves going up twenty or thirty feet in the air. I got the idea that they pull everything themselves, no doubt to dodge squashed customer lawsuits. I could try asking about what vehicles the wheels came from the next time I go there, though I don't know which person pulled them, and there are about six people scrambling around there.
Ranchero50 wrote:In other news while changing the oil on mine I found a big dog knot on the inside of my passenger front tire. Really makes me think I should figure out something for a spare and some way to change it.
Yeah, 'seems like a nice idea, especially if you're already doing something with the wheels. Though I've never actually used a spare tire in my life, I figured I'd prepare a set of five while I'm at it. I don't even think #50 has the spare tire mounting hardware under it any more.
Today's Update
I'm a bit stuck on the caliper clearance issue; I haven't decided whether to go ahead as-is and risk it, or try to find larger wheels.
I asked Wheel Vintiques this morning, and heard that:
  • They recommend a 1/4" clearance between the caliper and the wheel, but
  • It's okay to have less clearance than that; it'll work even if it's almost flush, as long as it clears.
I'm not sure what I can glean from this advice, which amounts to "you'll need 1/4", but not really."
Thanks again for replying Jamie!
Ranchero50
I think their comment says we sell wheels but we don't have something that will offer the same clearance. On my dually there's maybe 3/16" of an inch clearance. I have the largest calipers on the F350 and 16" dually wheels so IDK. My front wheels are coined Ford rims (back are Dodge rims) so I guess that clearance is factory OK for a 10k truck.
I did buy new tires for the front today. Got a pair of Starfire SF-510 LT's in 265/75R16's. I'm running 235/85's in the rear (same height). The fronts have 8" of tread, are 31" tall and give the truck a business look. They ride at least as good as the Firestones that were on it. The shop sells a bunch of them to contractors who like that they wear really well on overloaded work trucks and vans running down to DC every day.
No pics at the camera battery refuses to charge.
DuckRyder
Post by DuckRyder »
robroy wrote:...
Or "It will work, unless it won't work" :D
If Jamie has 3/16 and it works then yours should as well...
003Ryder
Post by 003Ryder »
Hey RobRoy, I finaly found some rims on an online selling site :woohoo: two where practically brand new and two other where "ok" I picked up these four rims/tires for 115.00$ in cash, I wish I could upload some pics but I have no idea how too. They have about the same space outside the calipers as the old ones. Anyway, thank you so much for all your help through this post and some Pm's you saved me some major $$$$ in this situation, can't thank you enough.
003Ryder.
1972 Ford F-250 Ranger XLT :fr:
robroy
Post by robroy »
Jamie, Robert and 003Ryder, thanks so much for replying.
Ranchero50 wrote:I think their comment says we sell wheels but we don't have something that will offer the same clearance.
Yeah, that sounds about right.
Ranchero50 wrote:On my dually there's maybe 3/16" of an inch clearance.
Thanks for this.
Ranchero50 wrote:I have the largest calipers on the F350 and 16" dually wheels so IDK. My front wheels are coined Ford rims (back are Dodge rims) so I guess that clearance is factory OK for a 10k truck.
All right, thank you; this is really helpful to know.
Ranchero50 wrote:I did buy new tires for the front today. Got a pair of Starfire SF-510 LT's in 265/75R16's. I'm running 235/85's in the rear (same height). The fronts have 8" of tread, are 31" tall and give the truck a business look. They ride at least as good as the Firestones that were on it. The shop sells a bunch of them to contractors who like that they wear really well on overloaded work trucks and vans running down to DC every day.
Hmmm, I'd be curious to see a photo, when you have a camera again.
DuckRyder wrote:
robroy wrote:...I'm not sure what I can glean from this advice, which amounts to "you'll need 1/4", but not really."
Haha yeah.
DuckRyder wrote:If Jamie has 3/16 and it works then yours should as well...
Thanks. Yeah, the piece of wire I ran around inside there was about 3/16", so there could actually be slightly more clearance than that. I guess I'll go ahead with these wheels.
003Ryder wrote:Hey RobRoy, I finaly found some rims on an online selling site :woohoo: two where practically brand new and two other where "ok" I picked up these four rims/tires for 115.00$ in cash, I wish I could upload some pics but I have no idea how too.
Hey, that's great! Congratulations. And you're welcome, though as always, the credit belongs to my generous FORDification mentors and not myself.
003Ryder wrote:They have about the same space outside the calipers as the old ones.
Ah... interesting.
003Ryder wrote:Anyway, thank you so much for all your help through this post and some Pm's you saved me some major $$$$ in this situation, can't thank you enough.
You're welcome Friend.
Today's Update
I received some additional advice from Rich (1972hiboy)--thank you Rich--on the two wheel types in a PM, and I've decided to take the time to make them all match. Even if I don't mount dog-dishes on them right away, having two different wheel types on there would probably be depressing later on.
So I've been in touch San Benito Auto Wreckers again, and they're going to find two wheels with the dog-dish retention humps for me, and swap out the two questionable ones. They're being really nice and easy going about it. Jamie, thanks again for the tip about wrecking yard conventions.
At least for the sake of good documentation, I'll try to get a more precise caliper clearance measurement of the factory wheels, and these new ones.
Jamie, Robert and 003Ryder, thank you again for your excellent replies.
Ranchero50
Some updated pics with the new sneakers. Front and rear are the same height, just the rear is thinner so the dually's don't rub.
