1969 highboy boxwood green
popeyes71
Re: 1969 highboy boxwood green
Post by popeyes71 »
Manny wrote:
popeyes71 wrote:The old saggy spring problem :lol: Yeah, mine were shot too, due to my truck living a hard work life! I had about a inch of clearance from the bottom of the bump stop to the top of the spring in the front. I ordered a set of springs from Alcan Spring in Colorado. The rear springs I had made to stock height specs and then had the front springs custom made so the truck sits level. Great company and the springs work great!
Got some measurements like center of the hub to fender lip?? Have the hardest time such as Lone ranger finding what these thing set like. Also when I see one I like nobody knows how its set up. Oh that's stock (With 40's) or 6 inches of lift (with 31's) Frustrating... :cuss:
I know exactly how you feel because I went through the same thing myself. I will get some measurements over the weekend and let you guys know. :thup:
-Popeye-
1971 F-250 4x4 Highboy
Lone Ranger
Post by Lone Ranger »
Awesome! I've been asking everywhere about lift and tire sizes. Your truck looks great Popeyes!
Kyle
Lone Ranger
Well it's been way to long since I worked on the truck and I should be able to get some things done this winter on it. Lately it's been slow to start and the other day it just clicked. Crossed the starter solenoid and it still just clicked so...out with the old-
And in with the new-
Also switched out my digital mega fuse with a new one- the old one got water in it and always read zero, even with the key pulled. I gooped up the new one with RTV so she should stay dry now.
New one on it- it read 14.8 with all lights off and running, and right around 12 with just accessorie on. I'd recommend using one of these if you have done the 3G swap. It cost me less than 20 bucks and it's super handy.
Not much, but felt good to work on it again.
Kyle
Manny
Post by Manny »
Lone Ranger showed my brother your truck yesterday. He no longer cares for mine he said yours is perfection narrow tires 300 six 4speed his new favorite... just figured you should know.
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
Lone Ranger
Awesome that's encouraging thanks! I do like the straight six- it runs smooth as a sewing machine but just doesn't sound aggressive. Not as much fun reving it up at a red light as my old truck. I do want a bigger tire but they gotta stay narrow :thup: I'm starting to get some blow by and it's sucking it back through the air cleaner- I'm gonna try just dumping over board. Hopefully I don't need vacuum to do that. I kinda don't want to do a rebuild but we'll see if it gets worse or not.
Kyle
popeyes71
Post by popeyes71 »
Lone Ranger wrote:Awesome! I've been asking everywhere about lift and tire sizes. Your truck looks great Popeyes!
Thanks Kyle! Sorry for the delay on the measurements; we had a family emergency. The measurements I took are from the center of the axle to the bottom of the wheel well opening. The front is 25 3/8" and the rear is 24". My truck sits fairly level but that was what I was going for. The tires on the truck currently are 265/75/16. After taking measurements, I was thinking that I was going to step up to a 34" tire. It should still give me a little clearance to still do some off-roading.
-Popeye-
cdnwillyg
Post by cdnwillyg »
:hj: popeyes would ou have a pic of the front end showing your tires and their relationship with the body? Is there any offset on the rims?
Sorry Kyle! :nono:
Stony Plain, Alberta, Canada
:drive:Willy
Lone Ranger
Thank you Popeyes! I'll measure mine and see what I need to do to get it to your height.
Kyle
hfdco4
Post by hfdco4 »
Where did you get the digital mega fuse.
:fr: FE390PC
Lone Ranger
hfdco4 wrote:Where did you get the digital mega fuse.
I got it off eBay. I think it's scorpion brand. It has a ground wire( which I wired to one of the mounting screws I used) and an external power wire( hooked it to the starter solenoid- otherwise it won't turn off)
Kyle
Manny
Post by Manny »
Lone Ranger wrote:Thank you Popeyes! I'll measure mine and see what I need to do to get it to your height.
YAY!!!!! :woohoo: I know isn't it nice to have measurement with some specs finally!!!
hfdco4
Post by hfdco4 »
Thanks Ranger :thup: :D :woohoo:
:fr: FE390PC
hfdco4
Post by hfdco4 »
:fr: FE390PC
Bullitt74
Post by Bullitt74 »
Great work Kyle! This truck keeps getting nicer and better! :D
Steve F.
Red Deer, Alberta, Canada
8)
1guydude
Post by 1guydude »
hows the truck man? Did u get monster tractor tires for it?!
lol
...seriously.
-d
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
