I couldnt find any specs or anything when I did mine so I did just what you said. LIned up and welded the brackets, probably not 100% perfect as I'm seeing inner tire were on the drivers side only. I should really take it to an alignment shop.CMH66F100 wrote:JG, great build....truck looks awesome been following it I'm in the middle of mine right now with a 05 crown vic PI front and a 96 explorer rear into a 66 F100 SWB hoping for the best but since you have yours done already you might be able to help. Is there a certain degree where the radius arms of the vic front end should be set at? I've looked all over and cant find anything. I noticed your post that you said once you had it in place you just made brackets that lined up to the mounting surface...if its that easy I'm on the right track...
Wish I had more to say about my truck, I did move again, in a bigger garage now. Still runs great! just get in a go.IN2FORD wrote:How bout an update?
Barry
