Thanks Crazy Horse.
Well, motor showed up at Ford around 2 so I headed down there and picked it up. I was pleasantly surprised for once, Not only were all the parts there, on time and they loaded it up for me. They gave me a $300 in store credit after the purchase I was not expecting..
Not to mention the engine came with more parts than expected!! New intake, water pump, idler pulley, motor picking eyes that made our job so much easier. Also came with all the sensors on the engine proper.
Got it home and got it all unloaded....did I mention how nice those picking points were?
We then worked on transfering all of the parts onto the new engine, accessories, alternator, injectors, new Pilot bearing, transmission spacer plate, exhaust manifolds, flywheel, clutch and pressure plate. I also pulled the oil pressure switch and ran three quarts of fluid through my pre oiler setup. You could hear the oil making its way back to the oil pan, and pulling the fill cap you could see it running out of the timing gears and the cam. It was pretty neat actually. Rotated the crank shaft while pre oiling as well.
Might just make it to T Hill after all....if I don't it will not be from a lack of effort
Its about ready for the front clip to go back on. I need to swap on a couple of pigtails on the harness for a change in connector at the Cam Solenoid.
I should be pretty close to firing it up tomorrow night.
Sean
